RG3120 problem..help? - Jemsite
post #1 of 6 (permalink) Old 04-21-2007, 04:31 PM Thread Starter
Hallo to all..
I need a helpfull advice for a friend of mine..
He has recently bought RG3120..2000. year of production..
With Lo Pro..!
The problem that he is experiencing with it is a string slippage..
The lowest E string, the thin one, is falling out of the neck very easily..
Problem is more obvious during more intense and more demanding playing..scale runs and stuff like that..
Is this common for this model..(caused, maybe, by the narrowness of the neck?)?
What could be the source of the problem..?
And what woudl be a solution..?
Anyon eexperienced similar problem..?
I appreciate any help..
Thank you..
pera_a777 is offline
post #2 of 6 (permalink) Old 04-23-2007, 01:18 PM
Re: RG3120 problem..help?
I'm guessing that you mean that the high E string is slipping off the side of the neck. This problem happens when either the neck or the trem is not alligned properly.
BTB007 is offline
post #3 of 6 (permalink) Old 04-23-2007, 02:58 PM
Could also be a technique issue
buddroyce is offline
post #4 of 6 (permalink) Old 04-23-2007, 03:41 PM Thread Starter
Anyone had similar experience with this model, or RGs generally..?
post #5 of 6 (permalink) Old 04-23-2007, 06:19 PM
I'd check the alignment of the neck, had that issue with my FP and the neck wasn't aligned properly. I straightened her out and no issue anymore.
GTR-MAN is offline
post #6 of 6 (permalink) Old 04-25-2007, 06:25 AM Thread Starter
Thanx..i will tell my friend to check it out..
Can you tell me what action should be taken in order to align the neck..?
Thank you very much..!
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 11:57 AM
JCM2000 DSL100 volume swell problem Joshka Gear, Equipment, Recording & Off Topic 40 04-14-2004 06:49 AM
Another RG3120 Problem adamcbest All Other Guitars (including Prestige) 5 04-11-2004 05:19 PM
RG3120 Problem.. Help adamcbest All Other Guitars (including Prestige) 2 04-07-2004 01:25 PM
rg3120 sustain problem K7 All Other Guitars (including Prestige) 5 05-19-2003 05:12 PM
