Rg320 Help! - Jemsite
post #1 of 6 (permalink) Old 05-01-2012, 09:45 AM Thread Starter
Exclamation Rg320 Help!
Hi,
I recently bought an Ibanez RG320 FM and it is a fantastic playing guitar. The edge 3 actually goes out of tune a lot. thought it was fixed, but wasn't, also the last two strings(Low E and A) go out of tune the most ast they can be tuned from the normal tuners. the problem is that I can still tune the guitar from the normal tuners even with the locks tightened. this only happens on the two strings. the guitar still goes out of tune. How can I fix both these problems?
Thanks,
William
yoyokidify is offline
post #2 of 6 (permalink) Old 05-01-2012, 10:16 AM
RGTFanatic's Avatar
Re: Rg320 Help!
Originally Posted by yoyokidify View Post
Hi,
I recently bought an Ibanez RG320 FM and it is a fantastic playing guitar. The edge 3 was set up properly and it never goes out of tune, except for the last two strings(Low E and A). the problem is that I can still tune the guitar from the normal tuners even with the locks tightened. this only happens on the two strings
Thanks,
William
It sounds like either the lock nut is stripped or the pressure pad has too deep of channels dug into it from pressure on the strings. inspect the entire nut to find out what pieces you need....posssiby the whole thing.
RGTFanatic is offline
post #3 of 6 (permalink) Old 05-01-2012, 10:40 AM Thread Starter
Re: Rg320 Help!
Edit: after playing some more the tremolo still goes out of tune when I use it. please help
post #4 of 6 (permalink) Old 05-01-2012, 03:49 PM
Re: Rg320 Help!
Def sounds like a locking nut issue.
kfssdude is offline
post #5 of 6 (permalink) Old 05-01-2012, 06:02 PM
RGTFanatic's Avatar
Re: Rg320 Help!
If the strings are slipping in the nut (which they obviously are) the guitar will always go out of tune, especially when using the trem. I suspect that the bolts that hold the nut onto the neck (from behind) are also loose. You'll want to check those as soon as you can. Tighten them enough to be firmly secure, but don't over-tighten. That's how people get the infamous nut joint cracks in their necks.
Inspect every part of the nut, then get back to us with the results. We'll be able to help you further when we know the situation a little better.
post #6 of 6 (permalink) Old 05-02-2012, 12:44 PM Thread Starter
Re: Rg320 Help!
ok here's a quick video showing the problems it has /watch?v=BF2ZAGLk_wc I can't put the video link because I don't have enough posts in, but go to youtube and add this after the youtube.com.
If that doesn't work, go to youtube find my channel called yoyokidify and look for the video called jemsite rg320 help on the channel.
thanks,
William
rg series , tremolo
MIJ RG320? moonlight All Other Guitars (including Prestige) 4 02-25-2011 06:31 PM
RG320 for £240 New!? Jolly Teaparty All Other Guitars (including Prestige) 7 10-13-2010 01:19 PM
rg320 JC_MIX All Other Guitars (including Prestige) 3 01-24-2007 10:53 AM
I just got a RG320 DX ZOMB13 All Other Guitars (including Prestige) 9 01-15-2007 03:03 PM
How are the RG320 DX? GuitarPlayerShaun All Other Guitars (including Prestige) 1 03-24-2004 12:28 PM
