RG320 sustains better than RG1570? - Jemsite
post #1 of 9 (permalink) Old 03-03-2008, 07:32 PM Thread Starter
I was playing on my 320 for a little while while waiting to get strings for my prestige. Yesterday I put new slinkys on the 1570 and even with new strings it doesnt sustain better than the mahogany 320. And I mean acoustically as well as plugged in. Both are stock pickups PWSNDS and V's. Is this normal? Action is a little lower on the 1570 but I can't see this contributing much.
Mister CCJ is offline
post #2 of 9 (permalink) Old 03-03-2008, 08:20 PM
Re: RG320 sustains better than RG1570?
I don't believe it . . .
ColinMmmmm is offline
post #3 of 9 (permalink) Old 03-03-2008, 08:27 PM Thread Starter
Could it be the slinkys? I don't remember whats on the other guitar. I know the mahogany of the 320 probably helps a little.
post #4 of 9 (permalink) Old 03-03-2008, 08:56 PM
If you get 10 identical RG1570s and 10 identical RG320s, each will have their own unique amount of sustain. The wood and the neck joint on the RG320 might just be that perfect, elusive combination to get that much sustain.
Petie is offline
post #5 of 9 (permalink) Old 03-03-2008, 09:36 PM
Key word : Mahogany
Lefty Robb is offline
post #6 of 9 (permalink) Old 03-03-2008, 10:04 PM
Different woods, hardware, neck profile/ thickness. there are a lot of factors and variables at work here.
speedy mcfeely is offline
post #7 of 9 (permalink) Old 03-03-2008, 10:10 PM
only the shape is in common. the neck joint the wood.. they are 2 diferent guitars pal..
Claudio Passamani is offline
post #8 of 9 (permalink) Old 03-03-2008, 10:15 PM Thread Starter
Yeah this is all true its just a little dissapointing in a way. Its a barely noticeable difference but I definitely noticed it after playing the other for a few days. Are EB slinkys good tone strings? And its probably far fetched but I'm thinking... how high should the single coil be set? Because its just about as high as the bridge humbucker which is maybe 2 mm from the strings.
post #9 of 9 (permalink) Old 03-03-2008, 10:15 PM Thread Starter
ok maybe 3-3.5 mm
bridge hum , bridge humbucker , neck joint
buy Rg320 or not to buy Rg320 pace520 All Other Guitars (including Prestige) 20 11-17-2012 09:41 AM
Modded RG1570 or RG2570E adil2552 All Other Guitars (including Prestige) 4 04-25-2007 05:08 PM
Very uniqe rg320 j.arledge All Other Guitars (including Prestige) 8 09-25-2006 05:06 AM
My new RG1570 impressions/questions momitch All Other Guitars (including Prestige) 5 06-29-2004 01:34 PM
Buying RG1570 or RG2570 ? Bellman All Other Guitars (including Prestige) 10 06-19-2004 01:37 AM
