RG320FM Edge 3 Problem - Jemsite
post #1 of 12 (permalink) Old 07-17-2010, 11:24 PM Thread Starter
Unhappy RG320FM Edge 3 Problem
I got a 07 RG320 in a trade, i loved it but it had no tremolo arm, no problem i set up the guitar so that the metal plate on the bridge is parallel with the body of the guitar, i was shocked that the RG320 stayed in tune 20X better than my Ibanez S Prestige. After a month the trem arm came in and i realized i had to raise the angle of the bridge because i like to use the arm backwards sometimes and it would hit the body. I raised the angle of the trem to where Ibanez says it suppose to be but now it dose not stay in tune at all. When i use i press the bar down to make the note flat and return the guitar is flat, if i pull the bar to make the note sharp and return the guitar is sharp.
Someone help me understand what the problem is and whats going on please and thank you!
AD1023 is offline
post #2 of 12 (permalink) Old 07-17-2010, 11:58 PM
Reviews: 3
Re: RG320FM Edge 3 Problem
which trem is on it...edge or edge III ???
mtldad is offline
post #3 of 12 (permalink) Old 07-18-2010, 12:01 AM
Reviews: 98
There are already a ton of threads concerning this, so you should use the search feature to find them. Also, visit Rich's site, ibanezrules.com and go to the tech section. Sounds like you might need to reaccomplish the setup with the bar installed and intonate the guitar.
AlaskaBat is offline
post #4 of 12 (permalink) Old 07-18-2010, 12:03 AM
Reviews: 98
You can also visit projectguitar.com
post #5 of 12 (permalink) Old 07-18-2010, 12:07 AM
Reviews: 98
Acording to the thread title, it's an Edge 3.
post #6 of 12 (permalink) Old 07-18-2010, 12:19 AM
Reviews: 3
ooops!!! sorry, reading faster than i can keep up with !!!
mtldad is offline
post #7 of 12 (permalink) Old 07-18-2010, 12:30 AM Thread Starter
can aneyone just tell me what the problem is or what its called? or even how to solve it
AD1023 is offline
post #8 of 12 (permalink) Old 07-18-2010, 12:37 AM
Reviews: 98
The first thing you need to do is follow the simplest suggestions provided. Did you redo the setup? Intonation? How about properly stretching the strings? You'll be better off trying these first than waiting for the guitar Gods to materialize in your home to fix it for you.
post #9 of 12 (permalink) Old 07-18-2010, 04:51 PM
Reviews: 98
Did any of these suggestions work?????
post #10 of 12 (permalink) Old 07-21-2010, 12:38 PM Thread Starter
nope its still on crack, think it would make a difference if i put a new pack of strings on?
AD1023 is offline
post #11 of 12 (permalink) Old 07-21-2010, 08:40 PM
Sounds to me like you used to have the trem basically resting against the body (because of the wedge shape of the Edge 3 it would be parallel to the body at this point) and that would explain the tuning stability. Now your issue sounds like you need to follow Alaska Bat's advice. New strings and a setup, intonation will probably do wonders for you.
jairic is offline
post #12 of 12 (permalink) Old 07-24-2010, 01:12 AM
Reviews: 98
If I can get Scotty to fix the transporter, I'll beam over and do it for you. Bwaaaaah haaaaaa haaaaaaaa...
320 , edge , iii , problem , rg320
RG320FM.. Edge 3 to Lo-pro Upgrade synth002 Tech: Setup, Repairs and Mods 18 06-17-2012 08:54 AM
edge pro problem. help? DanEwins Tech: Setup, Repairs and Mods 1 03-22-2009 12:40 PM
a little problem with edge II mr.jem555 Tech: Setup, Repairs and Mods 1 06-10-2007 08:27 PM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 08:59 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
