RG350 EX Custom Build - Jemsite
post #1 of 7 (permalink) Old 07-06-2010, 06:16 PM Thread Starter
Hey guys. I have a question. I bought an RG350EX body and a wizard II neck off of a RG320DX. My question is will I need to shim the neck pocket? Has anyone here taken their RD350EX apart, and was there a shim under the neck? Also, where was the shim located? Any pics would be great!!!! Thanks!!!!
walterh is offline
post #2 of 7 (permalink) Old 07-08-2010, 06:15 PM Thread Starter
Re: RG350 EX Custom Build
40 views aand no info? Please help if you can!!!!! Thanks!!!!
walterh is offline
post #3 of 7 (permalink) Old 07-08-2010, 06:46 PM
yeah it should fit.i have a rg350ym and its fitted with wizard2 neck so should be fine.
rob777vdy is offline
post #4 of 7 (permalink) Old 07-08-2010, 07:19 PM
Reviews: 17
If they are both Wizard 2 then it should fit
Speedabob is offline
post #5 of 7 (permalink) Old 07-08-2010, 07:22 PM
Reviews: 120
They should definitely fit, but by shim to do you a shim to adjust the neck angle in the pocket? A lot of bolt-on neck guitars come with shims in them. Set your guitar up, and if you can't quite get the action how you want to might want to experiment with different thickness shims to get the neck angle right for your guitar.
LonePhantom is offline
post #6 of 7 (permalink) Old 07-09-2010, 09:22 AM Thread Starter
Yes, I am wondering if most ibanez guitars, particularily rg series guitars come with shims under the neck from the factory???? Thanks for all you replies!!!
walterh is offline
post #7 of 7 (permalink) Old 07-09-2010, 06:41 PM
Reviews: 120
They quite often do.
rg350 ex
Custom Build Strat jemaholic Classified Ads: Guitars and Gear 0 04-07-2010 08:12 PM
Jem DNA Custom Build vanbuxton Ibanez JEM, UV, JS & Other Signature Models 4 07-09-2009 11:51 PM
How do you build your first custom guitar? carlos grijalva Tech: Setup, Repairs and Mods 3 06-16-2005 09:17 AM
So im gonna have EKG build me a custom.... Meedlyx10 All Other Guitars (including Prestige) 4 09-05-2004 01:59 AM
New guitar..... - I'm going to build a custom, here is what MorbidAngel All Other Guitars (including Prestige) 0 10-07-2001 06:14 PM
