rg370 questions... - Jemsite
post #1 of 7 (permalink) Old 11-02-2005, 02:01 PM Thread Starter
rg370 questions...
i have a few questions about the ibanez rg370
1) can i change the ep3 bridge to a ofr bridge without making any modifications?
2) has any1 got pics of an ibanez rg with emgs in it (h-h or h-s-h), preferably a shot in this angle:
if possible, could it be pretty big
i hope you are able to help me out
thank you very much
user01
User01 is offline
post #2 of 7 (permalink) Old 11-03-2005, 01:34 AM
Re: rg370 questions...
Yes, you can directly retrofit an Original Floyd Rose into an Edge III cavity. Someone on this website did it not too long ago. As for pictures of an RG with EMGs....
Hope that helps.
lyconxero is offline
post #3 of 7 (permalink) Old 11-03-2005, 12:59 PM Thread Starter
wow! perfect
thats the rg370 aswell
thanks alot dude!
User01 is offline
post #4 of 7 (permalink) Old 11-05-2005, 12:19 PM Thread Starter
Originally Posted by lyconxero
Yes, you can directly retrofit an Original Floyd Rose into an Edge III cavity. Someone on this website did it not too long ago. As for pictures of an RG with EMGs...Hope that helps.
thanks alot dude, is this your guitar?
if so, is it alright if you could take a close up picture of the electronics cavity so i could use it as a guide when wiring my emgs in my rg370.
i hope you can help me out
thanks alot dude
cheers!
User01 is offline
post #5 of 7 (permalink) Old 11-05-2005, 09:34 PM
Wish I could help you out, but I don't have a digital camera. I took that picture over the summer when I was staying with my mother pretty much right after I finished modding the guitar. EMGs are a tricky install if you've never done it before, so I would recommend having a professional do it. Also, the single coil wasn't a direct fit and had to be "modified" slightly to fit in the cavity.
post #6 of 7 (permalink) Old 11-06-2005, 02:55 PM Thread Starter
hmmm, i've intalled emgs before so i didnt have any worries, but now im not so sure since you had to make some modifications...
what kind of modifications did you have to make to the single coil thing?
cheers
user01
User01 is offline
post #7 of 7 (permalink) Old 11-07-2005, 02:29 AM
The single coil EMG S pickup was a rectangular shape that didn't fit into the route, so I had to do a little work filing the edges so that it would fit. Also, the pickup wouldn't mount the same way as the stock pickup so new holes had to be drilled. I don't know if anyone else had this problem, but I ran into it. It was more work, but it was definitely worth it. My guitar is infinitely more versatile thanks to that pickup.
floyd rose
Similar Searches
What is better ibanez rg350 or rg370
compare ibanez rg370 ex370
Wiring Diagram Questions - Schaller 5 way Switch - RG370 jlander Tech: Setup, Repairs and Mods 1 07-07-2010 01:20 AM
F spaced or not for my RG370 DX longi Pickups & wiring 12 12-31-2009 03:28 PM
New Pickups for RG370 DX (help me!?) MF_Kitten Pickups & wiring 11 12-22-2006 09:45 PM
New pups for my RG370 Spider-Skot All Other Guitars (including Prestige) 7 05-16-2006 03:45 PM
EMG's In my rg370 possible?(replies please!) jem_fanatic All Other Guitars (including Prestige) 21 08-17-2005 02:42 PM
