RG570 with new pickguard problem - Jemsite
post #1 of 25 (permalink) Old 05-07-2011, 03:20 AM Thread Starter
Hi guys!
Ok I have had this RG570 for about 8 years..It has been my mate in countless gigs and we have spent many frustating and at the same time rewarding musical moments all this years..
My first guitar I bought myself working my @ss off..I call it my "Peliroja" (Red-haired).
Even that today I have a better quality guitar,this RG570 always sounds and feels awesome..
However I like to explore new things and I changed the bridge pickup for a Tone Zone a few years back..I want to try another pickup in the neck soon!
I would never paint it but I decided to install it a pickguard to make it more interesting..so I bought this..I hope you like it!
Ok here's the problem..
The thickness of the pickguard is not giving the pick-up selector enough room to slide up or down with the knob..I had to remove it
The pick up selector started to give some problems during a gig..now with the pickguard defenitively I want to change it but I need one with the tip longer to have enough room to move freely with the knob..but it seems the size is standard
Anyone knows where I can find a longer pick-up selector? or any ideas to solve this??
Please help! I will really appreciate your feedback !
the-e-vid is offline
post #2 of 25 (permalink) Old 05-07-2011, 03:43 AM
Reviews: 13
Re: RG570 with new pickguard problem
You could file the area of the pickguard around the pickup selector. The pickguard for my universe has the area around the pickguard selector opening routed at about 40 / 60degrees. However this may prove difficult with a mirror pickguard.
-Wolfram
Wolfram is offline
post #3 of 25 (permalink) Old 05-07-2011, 03:45 AM
Reviews: 98
Look at the other thread about installing a pickguard on a 570 for some answers. The 570 wasn't made with a pickguard, so that should have been a thought when doing this--you just added some thickness to it, and the controls are too short. You'll most likely have to do a little routing of the body to accomodate the switch.
EDIT--found the other recent thread:
http://www.jemsite.com/forums/f18/ne...rg-111741.html
AlaskaBat is offline
post #4 of 25 (permalink) Old 05-07-2011, 05:16 AM Thread Starter
^^ by the pics in the other thread now I see what could be done..thank you.
indeed it will be a little bit difficult on a mirror guard :/
post #5 of 25 (permalink) Old 05-07-2011, 11:07 AM
I had the same problem. I just said screw it and go with no selector knob.
if you really want a knob without messing with the guard, get some super glue and fill the knob with it. then with the selector in position 1 or 5, push the knob on as far as it will go and hold till the glue dries.
RI_RGplayer is offline
post #6 of 25 (permalink) Old 05-07-2011, 12:56 PM
So what happens when he needs to remove the switch - for any reason?
gpenguins is offline
post #7 of 25 (permalink) Old 05-07-2011, 04:40 PM
RGTFanatic's Avatar
E-Vid: the best way for you to do this is to cut out the area around the switch from the body.... that way the switch can mount on the pickguard. It should be easy to cut through with a utility knife..... the wood is thin in this spot.
BTW... I love the look with the guard!!! Great 570!!!!!
Cut here:
RGTFanatic is offline
post #8 of 25 (permalink) Old 05-07-2011, 05:37 PM
Reviews: 98
Cut here:
Yep--that's exactly how to do it! Might even cut a little extra, maybe a few mm beyond the drawn lines.
post #9 of 25 (permalink) Old 05-08-2011, 02:21 PM Thread Starter
I thought in leaving it without the knob but it's kind of hard to switch bwt the bridge and the neck positions -the most used p's- in a middle of a song :/..it's just too short.
And yes,the fisrt thing that came to mi mind was to glue it!..however I dont think it will be a good idea in case of future needed modifications
post #10 of 25 (permalink) Old 05-08-2011, 02:28 PM Thread Starter
Cut here:
http://img40.imageshack.us/img40/2915/switchq.jpg
Thanks for he compliments!
Wow..well I've never done anything to my guitar except for changing pickups and disassemble it and clean/adjust it... and now this pickguard.
It sounds too easy..it is really that thin to cut it whit just a utility knife?
post #11 of 25 (permalink) Old 05-08-2011, 08:17 PM
RGTFanatic's Avatar
yup, just go slowly... no need to put a lot of pressure on it... just let the blade do the work.
post #12 of 25 (permalink) Old 05-08-2011, 08:36 PM
Reviews: 11
when in your life have you ever had to remove a switch tip.... its super glue, not a stainless weld man lol
linuxpenguin is offline
post #13 of 25 (permalink) Old 05-09-2011, 02:30 PM
So what does cutting out the body do? I don't have any guitars with pick guards, so what do you mean by, mounting it to the pick guard and not the body?
Davie Dynamite is offline
post #14 of 25 (permalink) Old 05-09-2011, 03:33 PM
RGTFanatic's Avatar
on pickguard equipped guitars the area around the electronics is wide open on the body (see pic) with this, all of the electronics are mounted to the pickguard.
post #15 of 25 (permalink) Old 05-10-2011, 12:31 PM
ohhhhh, I gotcha. Thanks
ibanez rg570 pickguard
RG570 pickguard, Give me your opinions RI_RGplayer All Other Guitars (including Prestige) 1 03-05-2011 02:56 AM
Pickguard for RG570 cornstar70 All Other Guitars (including Prestige) 1 08-03-2009 07:20 AM
Ibanez RG570... pickguard or not? Lordiesel All Other Guitars (including Prestige) 6 09-25-2008 04:24 AM
pickguard for rg570. speedy mcfeely All Other Guitars (including Prestige) 7 11-04-2007 07:38 PM
RG570 Trem problem shader Tech: Setup, Repairs and Mods 10 04-22-2005 08:50 PM
