RG570 and shielding paint in control cavities - Jemsite
post #1 of 5 (permalink) Old 08-10-2012, 05:58 PM Thread Starter
Hey, I have a 1991 RG570 that started buzzing recently and I found that the ground wire had come loose from the tremolo claw. I also opened up the control and jack cavities while I was there to see if everything looked ok. On a whim I decided to check the shielding paint that I found in those 2 cavities and it does not appear to be conductive at all according to the meter.
I'm not the original owner so I wanted to ask if these models did have shielding paint installed in them at the factory? Or did somebody just blow it and use the wrong kind of paint?
txflood is offline
post #2 of 5 (permalink) Old 08-10-2012, 06:06 PM
Reviews: 98
Re: RG570 and shielding paint in control cavities
The cavities should be shielded.
If the paint is gone-just use some copper tape.
AlaskaBat is offline
post #3 of 5 (permalink) Old 08-10-2012, 06:46 PM Thread Starter
Just to be clear, there is paint there. It just is not conductive and is useless. Can the stuff go bad over time?
txflood is offline
post #4 of 5 (permalink) Old 08-12-2012, 07:01 PM
I have a 2008 that didn't come with ANY conductive paint. Had a ground wire that ran to the single coil cavity. What it was grounded to? No idea.
I've since shielded it.
Ke^in is offline
post #5 of 5 (permalink) Old 08-24-2012, 04:01 PM
Reviews: 3
I've had a '91 RG 550 since the mid 90's and it always had a slight buzz that I could never identify the source of. Over the years I changed the pickups, jack, pots, switch, every bit of wiring and it was always there. Then I went completely overkill and copper tape shielded every portion of the inside. The buzz went away. So I say go for it!
This is what the inside looks like now, I don't think you'd have to go quite this far but I wasn't messing around.
knifehitz is offline
rg570 , shielding paint
Rf shielding paint hangingmonkey Tech: Setup, Repairs and Mods 18 02-15-2012 02:19 PM
Shielding paint ground Devon8822 Pickups & wiring 2 04-18-2010 08:57 PM
Pickguard shielding - aluminium or copper foil, or paint? axemanrio Pickups & wiring 6 05-24-2008 08:43 PM
Shielding with paint or copper foil? guitarkatana Pickups & wiring 9 12-31-2003 06:56 PM
Control cavity shielding MichaelQ Tech: Setup, Repairs and Mods 1 01-04-2003 04:31 PM
