RG652 neck/string issue - Jemsite
 4Likes
post #1 of 29 (permalink) Old 08-27-2018, 02:18 PM Thread Starter
Hi all,
First time posting here! Recently i bought an RG652 Prestige and after playing for a month i realized my light "e" string is slipping away more than usual especially during some weird pulloffs. It feels like "the string is too close to the end of the bottom end of the fret". Never had that many "string slipping out" while playing my S 5470TKS the last 10 years.
Is the RG652 neck "just like that" or is smth i can tune to somehow bring the "light e" string a bit closer to the b string or smth? maybe faulty product?
I am attatching some images showing what i described! Neck type is "Super Wizard HP"
Kapeliotis is offline
post #2 of 29 (permalink) Old 08-27-2018, 02:22 PM Thread Starter
Re: RG652 neck/string issue
Images
post #3 of 29 (permalink) Old 08-27-2018, 03:52 PM
site founder 0% owner
jemsite's Avatar
Welcome to the forum. Those photos don't show much really except roughly symmetrical string to fret-end clearance on both sides of the fretboard. The fretwork is meh, over cut slightly too short for me at fret 12-15 high-E (look at the gap between fret end and binding). Assuming the neck is straight in the pocket and nut 43mm you can use a 42mm nut to give more room or easier yet adjust the nut toward the low-E. Also a setup would help if you're fighting the strings/setup it makes all the heavier a touch. Good luck.
mike570 and Hoseki like this.
jemsite is offline
post #4 of 29 (permalink) Old 08-27-2018, 03:58 PM Thread Starter
i ve noticed some space between the light e saddle and the b string saddle. Can the light e saddle be moved closer to the b saddle? the Bridge is called Edge original. Thank you so much for your reply!
post #5 of 29 (permalink) Old 08-27-2018, 04:05 PM
jemsite's Avatar
saw that it looks moot from the photo, maybe different in person. Yes there might be a very-little-bit of wiggle room as the saddle is held by the one saddle block screw.
jemsite is offline
post #6 of 29 (permalink) Old 08-27-2018, 04:07 PM Thread Starter
Thanks for your help! I ll figure my way to move the saddle a bit!
post #7 of 29 (permalink) Old 08-27-2018, 05:16 PM
No fret can be cut past the edge of the fretboard, they are shaved on the edge. It's a winter build that has widened with the heat and humidity, and will shrink back in the winter. I love winter builds.
42mm nut is not an option, unless you think you can find a 430mm radius top mount, best of luck.
If you move the saddle over it will just touch the B saddle and you will get saddle buzz, which you absolutely do not want.
If your only problem is with the high E shift the neck so the low E is closer to the edge. Technically it should visually look like the low E is closer to the edge anyway as technically it's the center line of each E string that are supposed to center the neck, I do prefer the visual alignment which is usually never an issue to anybody with these wider necks.
That somebody would have trouble with these wider 58mm heel necks is kinda ironic as many complain they want their old narrower 56mm heel necks back [which never left enough string room to the end of the fret].
Rich is offline
post #8 of 29 (permalink) Old 08-27-2018, 05:55 PM
Try changing those crusty strings! When you're restringing, loosen the neck screws a bit and try pushing it a bit towards the treble side before locking it back down. Hopefully that solves your problem.
Takin' a Ride is offline
post #9 of 29 (permalink) Old 08-27-2018, 06:02 PM
but bass side.
Rich is offline
post #10 of 29 (permalink) Old 08-27-2018, 06:26 PM
He's right, those strings are horrifying, they're like a frat house toilet bowl after curry night. Are you a secret bass player?
sepulchrave is offline
post #11 of 29 (permalink) Old 08-27-2018, 08:35 PM
Contraction and expansion "should" be equal, I think someone overdo the fret beveling in that area.
Tuga666 is offline
post #12 of 29 (permalink) Old 08-27-2018, 09:23 PM
Let me know when you find frets that expand like wood.
mike570 likes this.
Rich is offline
post #13 of 29 (permalink) Old 08-27-2018, 09:36 PM
Meeee? Was talking about the wood obviously, the birdseye maple kind obviously then the fret work. Said something wrong?
Tuga666 is offline
post #14 of 29 (permalink) Old 08-27-2018, 09:42 PM
I see summer wood expansion, I see nothing different about the bevel. You may see or conjecture anything you like.
Rich is offline
post #15 of 29 (permalink) Old 08-27-2018, 09:53 PM
Hi Rich Could be the pic angle, cause the 11th fret end seems flush.
Tuga666 is offline
neck , rg652
RG652 - is the fretboard binding coated? chris101 All Other Guitars (including Prestige) 0 06-12-2017 03:45 PM
NGD Prestige RG652 (Nebula Green) Kabala All Other Guitars (including Prestige) 46 06-08-2016 08:57 PM
WTB Ibanez Prestige RG652 AHM 7 Stringer Classified Ads: Guitars and Gear 0 04-20-2016 02:44 PM
RG652 Jam (Semi Shred) Kabala Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 10-09-2015 12:31 PM
PRESTIGE RG652 goes out of tune way fast, common? newyork_jarl All Other Guitars (including Prestige) 27 06-18-2014 10:27 PM
