RG7620/7420 questions - Jemsite
post #1 of 23 (permalink) Old 02-14-2007, 09:33 PM Thread Starter
I just picked up a very customized RG 7 sting. A buddy of mine filled in the neck pickup route, switch and volume knob and repainted it an awesome pink with purple holoflake. The bridge pickup is an Evo7.
Here's a couple of pics he took before sending it to me.
Here's the thing, the bridge is stamped LO-TRS but the neck is stamped 7620. Also, the neck has the bubinga stripe. Did some 7620s come like that? I noticed on the specs page the 7620 was listed as a 3 piece maple neck while the 7420 was listed as maple with the bubinga stripe.
Is the LO-TRS interchangeable with any other (better) 7 string trem? I'm trying to figure out if this was originally a 7420 with a neck upgrade or a 7620 with a bridge downgrade. Any thoughts?
Thanks so much.
Travis is offline
post #2 of 23 (permalink) Old 02-14-2007, 09:46 PM
Re: RG7620/7420 questions
you have an RG7420, some of the early ones had 7620 necks on them
ibanezdiehard is offline
post #3 of 23 (permalink) Old 02-14-2007, 10:04 PM Thread Starter
Thanks a bunch.
So, is there another trem that can be dropped in place of the LO-TRS-7 without any modification? Or, do I need to make do with the current bridge?
Travis is offline
post #4 of 23 (permalink) Old 02-14-2007, 10:08 PM
I have a 7420 like that (bubinga stripe) and I have one with a one piece maple neck and scarf joint for the headstock.. both with lo-trs and japanese "F" serial numbers in the Magenta Crush color.
JackButlerGOT is offline
post #5 of 23 (permalink) Old 02-14-2007, 10:38 PM
jim777's Avatar
I'm pretty sure you can drop an OFR in there without modification. Since the trem and pickups were the only difference between the 7620 and 7420, most of the necks are marked 7620.
jim777 is offline
post #6 of 23 (permalink) Old 02-14-2007, 11:19 PM
i might be wrong, but the LO trs 7 is a japanese trem.
so maybe a LO PRO will fit in it's place?
post #7 of 23 (permalink) Old 02-15-2007, 10:04 AM
jim777's Avatar
The Edge trems and TRS trems don't replace each other without routing. The TRS and OFR trems generally do allow for a quick swap, though.
jim777 is offline
post #8 of 23 (permalink) Old 02-15-2007, 08:25 PM
i'd like to know if they do (without mod)...becuase i'd love to switch out my Lo TRS for an org. floyd!
7stringofablick is offline
post #9 of 23 (permalink) Old 02-16-2007, 04:52 AM
You will have to mod. I had to when I replaced the TRS of my 470 with an edge.
Aris_T is offline
post #10 of 23 (permalink) Old 02-16-2007, 04:55 AM
Awesome looking! I love one-humbucker 7 strings (ala F.Thordendahl/Dino)!
Aris_T is offline
post #11 of 23 (permalink) Old 02-16-2007, 07:00 AM
ok, i thought that the only reason the korean LO TRS wouldn't swap with an EDGE or LO PRO was because the string spacing was slightly different,
so i assumed cause the LO TRS on the RG7420 is japanese it would be a direct swap.
but if you had to mod with a 470 then it's the exact same senario except 1 extra string.
post #12 of 23 (permalink) Old 02-16-2007, 08:35 AM
Yep! . It's not hard though! Good luck and enjoy your new trem !
Aris_T is offline
post #13 of 23 (permalink) Old 02-16-2007, 08:56 AM
awesome guitar!! if you ever get tired of her, let me know!!
velocity is offline
post #14 of 23 (permalink) Old 02-17-2007, 05:08 PM Thread Starter
So, has anyone actually done an OFR-7 swap for the LO-TRS-7?
Also, what kind of mods were needed to swap to the Edge-7 bridge?
Travis is offline
post #15 of 23 (permalink) Old 02-17-2007, 06:48 PM
yeah, i'm up for her too. hahah
zeamc is offline
bridge pickup , edge trem , edge trems , maple neck , neck pickup , scarf joint , seymour duncan , trs trems
Similar Searches
jem 7 wiring diagram questions Koss Pickups & wiring 0 09-08-2005 12:21 AM
Interview with Andy Timmons - Questions? toneslave Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 1 12-18-2003 10:03 PM
A bunch of questions regarding an RG2020X Wadstein All Other Guitars (including Prestige) 0 12-17-2003 06:31 PM
Some questions regarding/Wood/Bridges/finishes etc etc Swirly Tech: Setup, Repairs and Mods 16 12-16-2003 02:32 AM
Ibanez JS Questions!!! - Please answer these questions I hav Ibaman Ibanez JEM, UV, JS & Other Signature Models 6 09-08-2001 02:10 PM
