RG7620 (floyd rose/edge experts NEEDED!) - Jemsite
post #1 of 6 (permalink) Old 03-06-2006, 03:48 PM Thread Starter
hi all,
ok here's the deal i got this great RG7620 in great condition off **** last week everything ids perfect but the trem is have ing problems (it's a edge lo-pro 7 BTW). it keeps going out of tune when i do vai's crazy tricks. i tried the chap-stick lubricent idea on the knife-edges it didnt work. i was wondering if a tremsetter would help with this problem.
thanks alot,
~n
DBDbadreligion is offline
post #2 of 6 (permalink) Old 03-06-2006, 04:47 PM
Re: RG7620 (floyd rose/edge experts NEEDED!)
Did you read the tech section at ibanez rules (banner above)?
Regards
André
fettouhi is offline
post #3 of 6 (permalink) Old 03-06-2006, 05:04 PM Thread Starter
Regards
André
which section should i read none of it is what i think i need accept angle of trem and i got that perfect already
post #4 of 6 (permalink) Old 03-06-2006, 05:49 PM
http://www.ibanezrules.com/tech/setu..._stability.htm
(hope it's okay to post a link to your site Rich)
Serratus is offline
post #5 of 6 (permalink) Old 03-06-2006, 06:07 PM Thread Starter
ok thanks for that site, i did a few things that i never tried. ill see how it works later.
post #6 of 6 (permalink) Old 03-11-2006, 10:45 PM
hi all,
thanks alot,
~n
Did you check the intonation? That's the very first thing you do when you buy a used guitar. Nothing's wrong with the trem system, you just have to go over everything. Even brand new guitars from the factory, sometimes the intonation is off. Check the nut (I presume you know what that is) and see if the two screws on the back of the neck are tighten (they can come loose), and depend on how hangover was the guy that put together the 7620's that morning.
Oh, last thing. After you check all those and everything is OK, and still goes out of tune. That's 7620 for you. I have 3 and only one stay in tune.
After awhile, you just have to say "whada ****".
Fossil_7 is offline
Needed: Floyd Rose 2 or Schaller in Chrome pinto79 Classified Ads: Guitars and Gear 1 05-25-2007 02:04 PM
floyd rose advice needed.... Jammy Tech: Setup, Repairs and Mods 6 02-12-2003 03:00 AM
Next best thing to FLoyd rose edge/lo pro?? - if not Edge/lo SilverSurfer2 Ibanez JEM, UV, JS & Other Signature Models 5 12-15-2001 07:18 AM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 12:06 AM
