RG7620 pickup and autograph questions - Jemsite
post #1 of 5 (permalink) Old 06-12-2010, 04:31 PM Thread Starter
I bought this used last week, and it's a really nice guitar, but I hate the bridge pickup. I don't love the neck pickup either, but this bridge pickup has got to go. I was just going to order a Crunch Lab, but then I noticed that these pickups are direct mount, and the ears on them are more of a triangle. So, does this mean that the crunch lab would work cause JP's pups are direct mount? Do I need to measure the ears on these and make sure that whatever I buy has ones of the same dimension or is there some standardization implemented across manufacturers for direct mount pup dimensions? Or... will any old pickup work?
Second question; this guitar (or at least the seller said it was, I paid no more for it) was autographed by Steve Vai. I dont' know if it's real or fake, and since there's no proof of it, it's probably worthless as a signature either way right? I guess the bottom line is, do I need to be worried about this signature wearing off?
Thanks a lot for the help guys!
jairic is offline
post #2 of 5 (permalink) Old 06-14-2010, 04:11 AM
Re: RG7620 pickup and autograph questions
RG7620s come with New7 (Dimarzio) pickups as stock, hence the triangular mounting tabs. So, you can install any Dimarzio humbuckers with no problems, man.
As for the signature wearing off, most probably yeah, it will wear off.
Hope that helps, man.
aj_foes is offline
post #3 of 5 (permalink) Old 06-14-2010, 10:05 PM Thread Starter
Yes sir it does, thanks!
jairic is offline
post #4 of 5 (permalink) Old 06-29-2010, 03:58 PM
Post a pic, most of us here know what Vai's signature looks like. As for it rubbing off, it probably will unless you get it clearcoated. Might be worth it. I have one of my custom guitars signed by both Satriani and Andy Timmons and it's def. worth protecting the sigs.
shreddersymphony is offline
post #5 of 5 (permalink) Old 07-10-2010, 06:48 PM
Yeah, I got a '98 RG7620 and I also found the bridge pickup to be horrible. Replaced it with an Evo7 as soon as I could. If I ever got another I'd throw the JP CL/LF set in there though.
Hunter Wingate is offline
RG7620 Production questions jazzedout All Other Guitars (including Prestige) 8 11-01-2008 09:33 AM
rg7620 pickup question. bmedeiros678 Pickups & wiring 3 02-15-2008 05:55 AM
RG7620/7420 questions Travis All Other Guitars (including Prestige) 22 03-04-2007 11:15 AM
Pickup combinations for RG7620 megadeth All Other Guitars (including Prestige) 15 01-21-2005 03:47 PM
Pickup sugestions for RG7620 SinepTaf All Other Guitars (including Prestige) 13 08-23-2001 09:15 PM
