RGA F-Spaced or not? - Page 4 - Jemsite
post #46 of 49 (permalink) Old 01-10-2008, 02:23 PM
Re: RGA F-Spaced or not?
At any rate, try to find a reputable service tech to work on your guitar. Just because they have SAM-ASH on the door doesn't mean the guy knows what he's doing. My guitar was returned with buzzing 4th, 5th & 6th strings and a loose 1st string tuner. I took it back and I ended up with high action and a buzzing 4th string! Mind you, originally it had wonderfully low action before he installed the breeds. For some reason he felt he needed to adjust the truss rod and polish the frets without discussing it with me. Needless to say, I've taken it to another shop to have it repaired. I'm crossing my fingers and saying prayers to the grand pubba in the sky.
Twebbz is offline
post #47 of 49 (permalink) Old 01-10-2008, 05:15 PM
Originally Posted by Twebbz View Post
Got the F-Spaced Breeds installed in the RGA121. All the strings line up on center with the poles except for the first string where the string is off the pole's center toward the outer edge of the pickup just a bit. The F-spaced pickup could still be a tad wider, so yes for this guitar F-spaced is the way to go.
Cool. Thanks for the info.
southpaw_lefty is offline
post #48 of 49 (permalink) Old 01-11-2008, 12:45 PM
FUNC...You should be able to get that "Master of Puppets" sound with the Breeds but it would depend on the amp and settings. The natural sound of the pickups is balanced across it's range. You'd have to scoop a bit for the sound you're looking for, maybe with an equalizer in your effects loop. Try the Boss GE-7. Certainly the smooth distortion and overall tone is there.
The breeds seemed like they were lacking alot of top-end to me but it has been a few years since I owned my DBK. I wouldn't have thought MOP tones at all but maybe that's just me. I usually run my amp EQ settings at 12 o'clock and let the guitar woods, pickups and my hands do most of the coloring since I use different guitars with usually different pickups in the same night for gigs. It would annoying as hell to have to reset my EQ everytime I swapped guitars.
Just my 2 cents.
screamndemon69 is offline
post #49 of 49 (permalink) Old 02-27-2008, 06:03 PM
Here are some pics of my F-Spaced Dimarzios for the RGA121:
And one of the original V7 and V8 pickups. I don't know if they are F-spaced or not:
-Rick
punchingboy is offline
air norton , air norton neck , amp settings , breed bridge , bridge pickup , bridge position , dimarzio breed , edge trem , evolution neck , neck pickup , neck position , neck pup , norton neck , paf pro , seymour duncan , spaced pickup , super distortion , tone zone , truss rod
RGA Series Lefty? integra All Other Guitars (including Prestige) 22 03-03-2007 07:41 PM
rga 121 wins!!!! hoockey All Other Guitars (including Prestige) 28 03-23-2006 01:40 PM
rga 121 or pgm 301 hoockey All Other Guitars (including Prestige) 9 02-24-2006 07:40 PM
Just got my Tonezone, but it wasnt F Spaced ElectriK Pickups & wiring 7 07-04-2005 02:43 PM
What is it mean by f- spaced? RG3120 Tech: Setup, Repairs and Mods 1 02-16-2005 02:20 PM
