RGT build - Jemsite
post #1 of 88 (permalink) Old 03-22-2012, 03:08 PM Thread Starter
RGT build
Just got an RGT of some description off the bay, basswood body with the usual 5pc maple walnut neck with dot inlays, I think its an RGT42. Bought it with no hardware whatsoever, not even frets! It was painted some awful blue when i got it but it looks metallic red/copper underneath. I did manage to scrape the blue off and found a bit of a serial number that I couldn't make out but it definitely said Korea. Here's some pics, hope someone can tell me what it is
Shelvock is offline
post #2 of 88 (permalink) Old 03-22-2012, 03:52 PM
RGTFanatic's Avatar
Re: RGT build
Yep, it's definitely an RGT42. If you take off more paint we'll be able to tell if it's an FMDR or other...........
Did you get it for a good price??
RGTFanatic is offline
post #3 of 88 (permalink) Old 03-22-2012, 04:09 PM Thread Starter
Re: RGT build
I'm one step ahead
No flamed maple I'm afraid but I've got a nice walnut veneer I'm gonna put on top
Paid 100 GBP for it which I thought was reasonable
Shelvock is offline
post #4 of 88 (permalink) Old 03-22-2012, 04:21 PM
Reviews: 17
Re: RGT build
I remember that RGT42 Been on ebay about 3 times ! I got offered it for 70 posted when the original owner had it.
You paid 100? previous person paid around 80
Speedabob is offline
post #5 of 88 (permalink) Old 03-22-2012, 04:45 PM Thread Starter
Re: RGT build
Wow thats amazing!
Shelvock is offline
post #6 of 88 (permalink) Old 03-22-2012, 05:24 PM
RGTFanatic's Avatar
Re: RGT build
Wow....I love the look of this........I'd be tempted to keep it as/is!!!!!
post #7 of 88 (permalink) Old 03-22-2012, 05:41 PM Thread Starter
Re: RGT build
I know what you mean, not bad for basswood is it. Things is, and I know alot of people will probably hate me for this, but I want to fill the trem cavity with a bit of maple and convert it to a string thru hardtail, so ill need to do something to cover the top, but I'll leave the back as it is. I'll put some more pics up soon and of the future progress.
Shelvock is offline
post #8 of 88 (permalink) Old 03-22-2012, 05:48 PM
Re: RGT build
awesome...looking forward to seeing this project progress!!
craigny is offline
post #9 of 88 (permalink) Old 03-26-2012, 08:04 PM Thread Starter
Re: RGT build
A few updates of the sanding progress... man I hate sanding sealer!
Sanding the horns is definitely the worst part...
All the paint off now, just got do a little smoothing out in the horns to get the shape right where they meet the neck (basswood is real soft ain't it!?) and then work up through the grades to get it nice n smooth
Shelvock is offline
post #10 of 88 (permalink) Old 03-27-2012, 09:14 AM
Re: RGT build
That's really tasty!
LolPatrol is offline
post #11 of 88 (permalink) Old 03-27-2012, 09:34 AM
Re: RGT build
looking really good!!! any idea what kind of finish youll be doing?? something transparent i hope to let those neck through woods shine
craigny is offline
post #12 of 88 (permalink) Old 03-27-2012, 02:14 PM Thread Starter
Re: RGT build
Gonna try a tru oil finish, I've had good results with Danish oil before but I know I need something quite durable with basswood being so soft so I thought tru oil would be the best bet. I haven't got the equipment to spray clear coats and don't really like smothering guitars in thick plasticky stuff
Shelvock is offline
post #13 of 88 (permalink) Old 03-27-2012, 08:16 PM
Re: RGT build
Tru oil will look awesome..i did a tele body with tru oil once it looked awesome..and a little gunstock wax after the oil...good to go!! its easy and it looks just as nice as a clear coat.
craigny is offline
post #14 of 88 (permalink) Old 03-28-2012, 09:15 PM
Re: RGT build
wow man that walnut veneer looks wicked...that's going to be a sharp ax!
Swirltop is offline
post #15 of 88 (permalink) Old 04-02-2012, 03:48 PM Thread Starter
Re: RGT build
Update time!
Routed the front and rear trem cavities today and made a block from some maple to fit the rear. My first experience with a router and after a little practice on some scrap I just went for it, did the front first and then the rear, the rear came out better because i got the hang of it more doing the front side, in hindsight I should of done it the other way round!
Some pics...
Ready to route
Front side routed square, sides are pretty straight
Rear side routed square, I left a lip and 4 screw holes so that I can still fit the trem cover to hide the block, might make my own trem cover from the walnut veneer with holes drilled in it for the strings to pass through and just glue it on and sand it flush with the body.
Filled with maple block, took forever to get it to fit, and even then I made it a bit small on the length because I didn't realise it was the corners stopping it from going in the hole! [email protected]! Some epoxy filler should sort that when I glue it in.
View from the front cavity, need to sort the pup routes when its glued in aswell
Shelvock is offline
fixed bridge conversion , refinish , rgt , veneer , walnut
New JS build andyt Ibanez JEM, UV, JS & Other Signature Models 60 12-20-2011 10:52 AM
First amp build... AlaskaBat Tech: Setup, Repairs and Mods 6 12-20-2010 03:45 PM
My first build brainsick13 Tech: Setup, Repairs and Mods 11 10-31-2009 07:13 PM
RG Build!! littlephil All Other Guitars (including Prestige) 85 10-14-2009 09:47 PM
To Build a Jem... Darkstar Ibanez JEM, UV, JS & Other Signature Models 6 10-20-2003 07:29 AM
