RX20 Series - Wrong Serial Number? - Jemsite
post #1 of 5 (permalink) Old 07-21-2019, 10:18 PM Thread Starter
Hi guys!
I have a old Ibanez RX20 and was thinking to do some mod on it but I found something very interesting.
The serial number on headstock says the guitar was made in Indonesia, but the serial number on it is C6045027 which means that the guitar was made in Cort's Incheon or Daejeon factory on Korea (right?!)
"Serial Number: C6045027 (8 characters)
Built: april 1996. serial: 5027
(factory: Cort Guitars, Incheon or Daejeon, Korea)"
Have you guys seen something like this? Anyone has a good explanation for that?
The guitar was actually made in Indonesia or Ibanez has mistaken?
Other thing I didn't figure it out is about the wood of the body. On Ibanez's website say that 1996 guitars of this model was made of Hardwood. Is it plywood or some other type?
Thanks in advance!
androliv is offline
post #2 of 5 (permalink) Old 07-24-2019, 03:49 PM
Re: RX20 Series - Wrong Serial Number?
I search for it but not find any appropriate results
sofialucas is offline
post #3 of 5 (permalink) Old 10-07-2019, 04:50 AM
Originally Posted by androliv View Post
Hi guys!
The serial number on headstock says the guitar usps tracking was made in Indonesia, but the serial number on it is C6045027 which means that the guitar was made in Cort's Incheon or Daejeon factory on Korea (right?!)
Thanks in advance!
I also need to know if its plywood or something else. Help is highly appreciated.
Thanks in advance.
Regards,
Oliver
OliverS is offline
post #4 of 5 (permalink) Old 10-07-2019, 11:49 AM
Was the serial number you gave (C6045027) found on the back plate at the neck joint? Or where?
00_Jagermeistro_00 is offline
post #5 of 5 (permalink) Old 10-07-2019, 06:48 PM
Reviews: 120
If it is an RX20, and not a GRX20 I would think it would be Korean. Ibanez weren't having guitars built in Indonesia back then.
If you take the neck off and have a look in the pocket you should be able to see if the guitar is solid wood or plywood. You'd see the tell-tail strips of ply.
LonePhantom is offline
ibanez rx , ibanez rx20 , rx series , serial number , wrong serial
