S Series Project has begun - Jemsite
post #1 of 13 (permalink) Old 09-29-2006, 10:07 AM Thread Starter
even before i have finished my other projects i have started a new one - a late 80's early 90's S540. i picked it up for dirt cheap ($56) so i figured it was worth a shot to try and rescue and enjoy.
here's a pic of it just arriving and out of the shipping box.
one word - UGLY
http://smg.photobucket.com/albums/v3...Anch=imgAnch11
here's the back - EEEEWWW.
http://smg.photobucket.com/albums/v3...gAnch=imgAnch9
i figured i had two issues to deal with when i bought it. first issue was a neck crack. not just a simple seperation but a full on crack that lifted the fretboard away from the neck. not sure who he had do the repair but whomever it was did a fantastic job and you almost don't even feel the crack. this is a non issue now after seeing and feeling it in person.
http://smg.photobucket.com/albums/v3...gAnch=imgAnch8
here it is after a few hours of sanding and i layed the neck and trem on it to get an idea of the finished look - well kinda.
many more hours of sanding to go
http://smg.photobucket.com/albums/v3...gAnch=imgAnch3
here's a shot of the neck after i spent a couple hours prepping and cleaning. i'm very happy with the neck. the headstock looks good, the back of the neck is in good shape, neck crack was reapired correctly, fretboard is nice and dark with a nice grain and the frets have very little wear. so far so good.
http://smg.photobucket.com/albums/v3...gAnch=imgAnch4
you can see in some of those pics that someone tried to drill a 3rd hole on the body. i'll most likely end up putting dummy knobs on it. i would prefer no tone controls if i get the pups installed and just use my volume for all my control.
i plan to refinish with a clear coat if possible. i would rather that than painting it.
i'm getting all the parts together (i have most of what i need) and will try to find another Double Whammy dimarzio for the bridge and maybe a PAF for the neck.
i'll repost as i progress.
screamndemon69 is offline
post #2 of 13 (permalink) Old 09-29-2006, 10:40 AM
Re: S Series Project has begun
Since it's already stripped to that point, and you only want a single vol control, why not go ahead and fill the extra holes? That would look better than a dummy knob. --Jason
jkahrs is offline
post #3 of 13 (permalink) Old 09-29-2006, 12:03 PM Thread Starter
if i could get the filled spots to blend in enough then that would work. the guitar would look that much cleaner with the holes filled and only one knob.
i need to figure out how to match and blend if i want to do it. hmmmm...
i'm getting the 3 way cover, 3 way switch and few other odds and ends shortly so it shouldn't be more than a couple weeks to get this one back together. it will take a little longer to track down the Dimarzio Double Whammy bridge pup though and especially if i go creme/blk.
post #4 of 13 (permalink) Old 09-29-2006, 01:17 PM
Saw some S back plate cavity covers on the-bay just a while ago.
ashbass is offline
post #5 of 13 (permalink) Old 09-29-2006, 02:08 PM
Lookin' good so far. Keep us updated as you go of course. For the price you bought it for, its well worth it. And its nice to have a project from time to time. Should be brilliant when done!
the.godfather is offline
post #6 of 13 (permalink) Old 09-29-2006, 02:50 PM Thread Starter
you are one of the parts gurus i see selling stuff all the time. i'll have to take a look or i might even have to custom cut a set. it has a couple sets of holes for each plate and none of the plate holes are countersunk like an RG's so it shouldn't be a big deal cutting them if i need to.
this should be fun as long as the neck is cool (no twists, warpage) and also get to try my hand at a clear coat again.
post #7 of 13 (permalink) Old 09-29-2006, 02:52 PM
Looks like it has a lot of potential.
If you're determined to fill the two redundant holes, I think it'd be best to paint the wholy body so that there are no visible seams between the body and the 'fills'.
Planeflux is offline
post #8 of 13 (permalink) Old 09-29-2006, 05:41 PM
$56??? Bargain mate! Why do I always miss these deals...
dannymills is offline
post #9 of 13 (permalink) Old 10-01-2006, 09:54 PM Thread Starter
i'll check with a friend who is a very talented wood worker and see if he has any ideas about filling the holes. i would really like to go natural using a light coat of Formby's tung oil and a clear poly coat. painting would be a last resort.
as this project comes together, i'll keep updating.
it was a cheap buy but you never know what you might be getting into. i figured i was taking a chance and until i finish it and can actaully play it the jury will be out on whether it was a good buy or not. (fingers crossed)
post #10 of 13 (permalink) Old 10-01-2006, 10:58 PM
Flobanez's Avatar
Looking at the before and after pics, what an improvement, you did a great job, it looks really nice so far.
Flobanez is offline
post #11 of 13 (permalink) Old 10-01-2006, 11:17 PM
+1!
Cheers
Nickelo is offline
post #12 of 13 (permalink) Old 10-01-2006, 11:23 PM
Cool!
C.Thep is offline
post #13 of 13 (permalink) Old 10-03-2006, 06:59 AM Thread Starter
thanks for the kind words and taking time to check out my progress.
i am hopeing that i can clear it but it really depends on how well the old finish comes off. the white primer on the back is being a bear and taking some serious elbow grease to remove. the top is 99% sanded at this point and it is starting to really look nice. i wiped the top with thinner to remove the dust and the wood grain and color just popped out nicely. this will look awesome if i can keep on track with a light tung oil and clear coat.
more progress (and pics) to come.
bridge pup , cavity cover , clear coat , tung oil
Ibanez Fern Project Guitar (finally completed!) stratoskier All Other Guitars (including Prestige) 18 04-27-2006 10:21 AM
x series neck question nightfiend14 All Other Guitars (including Prestige) 0 07-27-2005 12:55 AM
WTB: Beaten/Played Jem for restore/custom project Devo Classified Ads: Ibanez JEM/UV Guitars 0 05-17-2005 12:34 PM
Project: RG-IDOL ibanez otaku Tech: Setup, Repairs and Mods 18 10-31-2003 02:36 AM
Operation unknown has begun - my UV conversion project! littlegreenman Ibanez JEM, UV, JS & Other Signature Models 26 03-27-2001 11:50 PM
