S series switchplate - are they all the same - Jemsite
 1Likes
  • 1 Post By LonePhantom
post #1 of 9 (permalink) Old 07-04-2018, 02:29 AM Thread Starter
Reviews: 120
I've been eyeing off a desert yellow 540S available locally, which appears to be in reasonable condition, bar a rather significant neck joint crack on the bass side of the body, and a broken switch plate. My question is, if I were to purchase the guitar, are replacement switch plates all the same for the S series, or have they varied over the years. It's probably going to be tricky to locate a vintage one if they are differing over the years.
Thanks in advance for any help
LonePhantom is offline
post #2 of 9 (permalink) Old 07-04-2018, 03:46 AM
Re: S series switchplate - are they all the same
I know the SA's had a different type plate in that it attached different [I've forgotten what was different about it as it's been too long], although the outside of the plate looked the same. I do not know if that effected any of the S models,
Rich is online
post #3 of 9 (permalink) Old 07-04-2018, 10:37 PM Thread Starter
Reviews: 120
The current ones listed for S series have the plate attached to the body with nuts in the cavity, does that ring true to the older ones?
post #4 of 9 (permalink) Old 07-05-2018, 01:23 AM
You could get lucky and find somebody here with a vintage s con cover missing, or you can just ask the guy to take his off and tell you. Or if you're serious go look at it ready to buy it knowing if it mounted with the nuts they're $10 and available, and if they don't they're not.
Rich is online
post #5 of 9 (permalink) Old 07-05-2018, 11:41 AM
How old is it? I can check mine if it's the same era... I need to buy a new 5-way switch for mine anyway and need to confirm what type is in there.
FireEagle is offline
post #6 of 9 (permalink) Old 07-06-2018, 09:31 AM
I don't know all of the different "generations" of S models, but mine is a '92 540S and has the type with two nuts on the inside of the cavity.
post #7 of 9 (permalink) Old 07-10-2018, 12:29 AM Thread Starter
Reviews: 120
Sounds like they've retained at least a similar design config. It's a DY S series, so similar vintage to yours. Block heal from memory
FireEagle likes this.
post #8 of 9 (permalink) Old 07-20-2018, 10:38 PM
The early Sabers had just just a plastic scratch plate cover for 5 way surround mounted with screws,by 90 they had a moulded hump type surround with allen head bolts and nuts mounted from cavity. This had to do with the length of the selector lever sticking out from the body,the hump version making things neater. Both are the same shape and dimensions so retro fitting hump style should be fine if you are changing the 5 way to a new unit. However the original 5 way MAY have a shorter lever and not work with the modern hump surround. I can't be sure though as i have never actually swapped out an old 5 way.
corey j grieve is offline
post #9 of 9 (permalink) Old 07-23-2018, 12:25 AM Thread Starter
Reviews: 120
thanks for the advice. It sold before I could have gotten to it anyway. Better I save my money.
replacement , s series , switchplate
To all 540PII owners, are all necks the same? bdk All Other Guitars (including Prestige) 3 01-08-2011 05:08 AM
Lo-Trs vs. Trs II - they really aren't the same thing butch All Other Guitars (including Prestige) 8 01-22-2010 01:16 PM
Pickup Screws...Are they all the same lazz Pickups & wiring 9 10-30-2007 09:38 PM
Body woods - are they all the same per model #? YngVaiTriani Ibanez JEM, UV, JS & Other Signature Models 5 08-23-2001 06:45 PM
What's with all the 555s on Ebay? - They're all over the pla Anonymous Ibanez JEM, UV, JS & Other Signature Models 5 05-30-2001 03:02 PM
