S5470 Prestige Issue - Jemsite
post #1 of 5 (permalink) Old 02-15-2009, 12:14 PM Thread Starter
Bought a new S5470 Prestige around Christmas and happy enough with it apart from one thing.
Problem seems to be with the pickup selector in positions 2 and 4. It sounds pretty awful. The 6th and 5th strings have decent output with a good bit of bass but once you hit the D, G or B strings the volume total fades and it sounds incredibly tinny.
I've never experienced this before, so I'm not sure if it's an issue with the pickups or what. Seems coincidental though that it happens with both bridge and neck pups.
Sound from bridge & neck pickups (pos 1 and 5) is fine. I bought it online from the States (I'm in Europe) so can't get the supplier to check it out easily, he told me to bring it to a guitar tech to check out.
Thanks in advance for any advice.
GuntherLust is offline
post #2 of 5 (permalink) Old 02-15-2009, 12:33 PM
Re: S5470 Prestige Issue
raise the middle single coil. It sounds like someone set it far too low and thats why you're not getting much output from it. The problem is less pravalent on the thicker strings, because theres more ferromagnetic mass there for the pickup to sense.
GuitarBizarre is offline
post #3 of 5 (permalink) Old 02-15-2009, 12:55 PM
Or wire it in parrallel as opposed to series. More output, without it obstructing your picking.
skins345669 is offline
post #4 of 5 (permalink) Old 02-15-2009, 01:22 PM Thread Starter
Thanks GuitarBizarre.
I tried raising the height of the single coil pickup, and it didn't fix the problem. While the output from the middle position has improved, the noticeable difference between the middle two strings (really low and tinny) and the other strings on positions 2 and 4 is still really prevalent.
Perhaps it is something to do with the wiring after all. I'd be reluctant to mess about with the insides so early in the guitar's life - best to send it back to the supplier?
post #5 of 5 (permalink) Old 02-15-2009, 01:25 PM Thread Starter
Thanks mate, I really don't want to be going inside it just yet though. I could take it to a tech but perhaps it's best just to send it back?
pickups , prestige , s5470
S5470 vs SV5470F JoshuaLogan All Other Guitars (including Prestige) 22 06-05-2010 01:08 PM
Which one should I get RGT320Z or S5470 Onlytheclouds All Other Guitars (including Prestige) 1 12-31-2008 02:35 AM
SV5470f, s5470, or a used s540? JameyF All Other Guitars (including Prestige) 9 11-12-2008 07:42 PM
New colour for the S5470 acdc51502112 All Other Guitars (including Prestige) 6 10-27-2008 08:26 PM
Ibanez S5470 Prestige Evo II All Other Guitars (including Prestige) 22 03-03-2008 04:05 PM
