s7420 EMG's, Need some help [pics] - Jemsite
post #1 of 19 (permalink) Old 09-27-2005, 04:50 PM Thread Starter
So here is what I have going on:
I've routed it out and fit twin emg 81-7's in it, but I have a few questions and you guys always have the answers.
Can I use the original input from the S? I heard that they were stereo inputs.
Also, I purchased a 3-way blade switch and have never wired one of these with emg's, Any advice? I can't seem to find the diagram for this type of switch:
Navarone is offline
post #2 of 19 (permalink) Old 09-27-2005, 05:15 PM
Re: s7420 EMG's, Need some help [pics]
On that type of blade switch, the 1,2,3,4,5,6,7,8 inline leads correspond to the 1,2,3,4 (side a) and 5,6,7,8 (side B) dual-line leads of the basic 3-way.
I have a schematic for wiring EMG's, but it uses the dual-line (4 leads per side) instead of the 8-inline. With some experimentation, and the basic diagram, it's not too hard to figure out, though.
How did you do the route? I'm considering doing the exact same thing on my Ibanez 7, and I want to do a nice job and protect the finish. Any tips are great!
The Dark Wolf is offline
post #3 of 19 (permalink) Old 09-27-2005, 05:47 PM
That does look good, nice christmas lights too. Now get a lo-pro 7 and call it a mod
sniperfrommars1 is offline
post #4 of 19 (permalink) Old 09-27-2005, 05:52 PM Thread Starter
I used a hand held Dremel of all things, and just took my time. The easiest way that I found while practicing with blocks of wood is to use a fine sanding bit on the Dremel near the finish. It makes a smoth clean edge and looks really nice. As for internal routing, I just used a basic routing bit and sunk in cavaties for the wires. after it was all cleared out and I was happy with it, I used flat black paint and a brush in the inside to clean it up. I was worried that depth would be a problem and I would have to sink the pickup in further than the old pickups, but it wasn't a problem at all.
Navarone is offline
post #5 of 19 (permalink) Old 09-28-2005, 03:27 AM
Excellent Navarone. Thank you. I appreciate the info. If I do it, and run into a problem, look for a private message
post #6 of 19 (permalink) Old 09-28-2005, 04:37 PM
looks good! you should get rid of that lo-trs P.O.S. and get a lo-pro edge.. it requires some mods but easy ones! but still, good job with the EMG's!
ibanezrocker61 is offline
post #7 of 19 (permalink) Old 09-28-2005, 04:41 PM
I just installed EMG 707's in an RG7621, or what i'd like to call, RG7PWH. Anyway, i used the dremel as well. Takes longer but much more accurate. Last time i installed emg 707's i used a router and it didnt come out half as nice.
1wi11 is offline
post #8 of 19 (permalink) Old 09-28-2005, 05:04 PM Thread Starter
That's next.
Navarone is offline
post #9 of 19 (permalink) Old 09-29-2005, 05:15 PM
That's next.
sweet! post pics when ur done with that!
post #10 of 19 (permalink) Old 10-02-2005, 12:49 PM
When you guys did the route, did you use the Dremel freehand?
post #11 of 19 (permalink) Old 10-02-2005, 03:01 PM
i did. i sat on a piano bench with the bench between my legs faceing out from me. Then i put the guitar body down in front of me. I felt this gave me the most stable stance to prevent slip ups. Then i bent foward and used both hands on the router like chairlies mother washing clothes in the original Charlie and the Chocolate factory. I put masking tape around the pup hole as boundaries so i wouldnt route too much off the body. Then again, i did plan on using a pickguard from the start, so for me it didnt have to be perfect.
And by the way, since theres no more 5 way switch for me, that area is where i place the 9V battery held by this...
http://www.keyelco.com/products/prod52.asp
I'm using the aluminum chassis one with the solder terminls. This will replce the original 707's battery clip.
1wi11 is offline
post #12 of 19 (permalink) Old 10-02-2005, 07:18 PM
Sepsis, awesome! Thanks. I think that's the way I'll try it as well (after practicing a few times on some boards. )
post #13 of 19 (permalink) Old 10-03-2005, 02:12 AM
Flobanez's Avatar
Nice mod, Navarone.
I have mine stock. I actually like the V7(7) and V8(7) pickups. They've grown on me.
Flobanez is offline
post #14 of 19 (permalink) Old 10-03-2005, 02:34 AM Thread Starter
Yes. I took out the old pickups and laid the 81-7's on top on the area and traced it out and worked very slowly checking the fit over and over. It was fairly easy. It’s just getting the nerves to start hacking away at your guitar.
Navarone is offline
post #15 of 19 (permalink) Old 10-03-2005, 09:19 AM
Yes, getting the nerves is definately the biggest step.
1wi11 is offline
guitar body , pro edge
S7420 snowblind All Other Guitars (including Prestige) 1 12-18-2008 09:41 PM
WTB: S7420 nicknuisance Classified Ads: Guitars and Gear 0 04-25-2007 09:53 PM
WTB: Ibanez S7420 revsharp777 Classified Ads: Guitars and Gear 1 03-29-2006 08:46 PM
S7420, anyone have one? VforVendetta00 All Other Guitars (including Prestige) 0 01-12-2003 04:55 PM
what's the value of my s7420? legiah All Other Guitars (including Prestige) 2 05-23-2002 06:11 AM
