Sanding a pattern into a guitar finish - Jemsite
post #1 of 13 (permalink) Old 06-24-2012, 06:46 PM Thread Starter
I recently painted my RGT42 with black, then red enamel paint, with the ultimate goal being to sand parts of the red finish to create a mottled effect with the two colors. I started in dry sanding the back side by hand (just to see if it would work), used 220 grit to get through most of the red and 600 grit to try and come through more gently. So far the results have been underwhelming, with the revealed black looking more grayish with flecks of red, and the red surrounding the sanded patch turning an orangish pink. Has anyone ever tried this before, and am I going at it wrong? Or should I give it up and leave it red?
WholesaleWNG is offline
post #2 of 13 (permalink) Old 06-24-2012, 06:59 PM
RGTFanatic's Avatar
Re: Sanding a pattern into a guitar finish
We'd have to see pics of what you have and a better description of what you want for an end product.
This sounds like a cool idea, I just don't know what your aiming for.
RGTFanatic is offline
post #3 of 13 (permalink) Old 06-24-2012, 09:00 PM
Reviews: 37
wet it and see the colors ,as paint tends to look weird when sanded before clear.
andrewsfury is offline
post #4 of 13 (permalink) Old 06-24-2012, 10:04 PM
It sounds like what you are describing is a finish similar to popular Asian furniture, which is black with little hints of red showing through?
If so you did the coats reversed. You want the dominant color on top, so you can "fatigue" it for faint secondary color showing through. I think the way you did it, with red as a top coat and black underneath, red will be the dominant color of the guitar (from across the room it just looks red) and the black would be really really subtle. Generally this effect looks more dramatic if you have the bright color peeking through the black. The black peeking through is, as you described, underwhelming.
kfssdude is offline
post #5 of 13 (permalink) Old 06-24-2012, 10:11 PM
That's how they finished the Urushi's (there are dozens of layers, and a special kind of paint):
Also search for the RG-Paint models, not sure but I think they were done the same way.
Whatever you do, you'll have to choose a paint that cures completely between coats. If the top coat melts into the base coat, you won't get a good contrast.
just4kinks is offline
post #6 of 13 (permalink) Old 06-24-2012, 10:45 PM
IbanezFreak777's Avatar
Reviews: 25
Same as my RG Paints.. They are multi layered painted and then sanded in spots...
IbanezFreak777 is offline
post #7 of 13 (permalink) Old 06-29-2012, 01:36 PM Thread Starter
Sorry about the delay, I haven't had access to a camera. Well this is what I've done so far, and the pic at the bottom is where I got this sanding idea (this was posted by andyt a few weeks ago, I just clipped it). Not sure how to post the photos on here, dont have a photobucket account so I'm just posting the FB album.
post #8 of 13 (permalink) Old 06-29-2012, 01:36 PM Thread Starter
Dumb 10 post requirement. Ok, here's the link: http://www.facebook.com/media/set/?s...8336458&type=3
post #9 of 13 (permalink) Old 06-29-2012, 01:53 PM
Not really any insight to what you're doing but I just had to comment on that black and green guitar. that guitar looks sooooo badass
Boombatty is offline
post #10 of 13 (permalink) Old 06-29-2012, 03:11 PM
Reviews: 4
Re: Smexy guitar
I love it every time this guitar is posted!!!!
fwd0120 is offline
post #11 of 13 (permalink) Old 07-02-2012, 04:29 PM
RGTFanatic's Avatar
I would sand out the orange peel, do another coat of black, or maybe even do several more coats of each....then start to sand out your pattern. Also, I would use a lot higher grit than what your using now. I'd use 320 or higher wet or dry paper (using it wet).
post #12 of 13 (permalink) Old 07-10-2012, 11:51 AM
IMHO: RGT looks so awesome when they're stripped down to wood, i'd sand it down and finish it with dye instead!
But that's just me!
As for orange peel, you need to let it dry and sand it with realy fine grit wet sand (i'd use 800+) between the layers to make it realy leveled. After, same goes for the lacquer and, in the end, you use some sort of coumpound to make it "glass like"
t1mman is offline
post #13 of 13 (permalink) Old 07-10-2012, 12:04 PM
Reviews: 98
But that's just me!
Polishing compound. Then, buff it out.
AlaskaBat is offline
color , paint , sanding
Paradiddles on the guitar, plus fantastic cool little sweeping pattern! mortenfaerestrand Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 05-15-2011 05:18 PM
Neck sanding, Finish prydogga Tech: Setup, Repairs and Mods 0 06-17-2009 09:00 AM
Further Sanding Advice Needed for Natural Finish! Pics! GuitarEvan07 Tech: Setup, Repairs and Mods 6 02-13-2009 08:46 PM
do you need to have a guitar painted after sanding? hachimako Tech: Setup, Repairs and Mods 1 07-05-2006 04:15 PM
Sanding off the finish - on my rg550 Noodles Tech: Setup, Repairs and Mods 7 04-30-2001 09:40 PM
