Schecter A 7 plus - any info? - Jemsite
post #1 of 2 (permalink) Old 05-07-2004, 05:53 AM Thread Starter
Hallo...I have seen this beautifull 7 string guitar at www.schecterguitars.com so i was wondering if someone on this forum have any experience with it or maybe owns one? Also, i am not sure that it is stil in producing, since it is put under "past models" on the site above mentioned...but anyway, i would like to get used, if it is good....that is the main reason i am opening this topic...
I am especially interested in its tremolo system, licensed FR...is it any good...
thank you...
pera_a777 is offline
post #2 of 2 (permalink) Old 05-08-2004, 08:05 PM
I've got a Schecter Revenger-7 (similar guitar, just much much cheaper: flat top, cheap pickups, hardtail, dot inlays, simple finish, etc.) and I can say you can't go wrong with Schecter. The only things you should be a little worried about are the bridge (as this is not a hardtail) and whether or not you'd be comfortable playing that guitar. The Avenger/Revenger shape is very awkward, the upper strap pin is on the back of the horn on mine and if you play sitting down you get poked in the ribs, and also it could really use an arm contour. It's also kinda neck heavy, and the neck takes some getting used to (it's not a thin, Ibanez-type neck).
Two hands31 is offline
dot inlay , dot inlays , schecter revenger , tremolo system
Info on a Schecter Spitfire? RG_FANMAN All Other Guitars (including Prestige) 2 05-02-2011 05:24 PM
Schecter C-1 FR prestigeaxes All Other Guitars (including Prestige) 6 12-31-2006 09:39 PM
Schecter C-7...? Euthanasia All Other Guitars (including Prestige) 25 10-10-2006 02:45 PM
8 strings: the info - Info please mojo All Other Guitars (including Prestige) 12 03-07-2006 06:10 PM
Schecter V7's - Anyone Own One rlintz All Other Guitars (including Prestige) 3 01-23-2002 10:56 AM
