Set up after removing the neck..help please :-) - Jemsite
post #1 of 10 (permalink) Old 06-11-2005, 10:30 PM Thread Starter
TVE
Question Set up after removing the neck..help please :-)
Hi,
I have recently removed the neck on my 75 Fender Strat and I have never adjusted any setup before. What should I be doing?
Cheers
Tania
TVE is offline
post #2 of 10 (permalink) Old 06-12-2005, 05:47 AM
jemaholic's Avatar
Re: Set up after removing the neck..help please :-)
Well, that could be tricky...why did you take it off if you don't know what your doing?
I'm sure you can find websites that can help.
jemaholic is offline
post #3 of 10 (permalink) Old 06-12-2005, 06:29 AM Thread Starter
TVE
Cool Re: Set up after removing the neck..help please :-)
Because I needed to check what year she was.. dont worry i didnt do it just for something to do.
TVE is offline
post #4 of 10 (permalink) Old 06-12-2005, 06:42 AM
When you put the neck back on always make sure that you don't over tighten te screws. I know you won't but its just a warning.
Tom Gilroy is offline
post #5 of 10 (permalink) Old 06-12-2005, 08:39 AM
those 70's strats are built like weapons. unless you changed your set-up in removing the neck, i would think you'd just put it back together and let it settle a little while once it's strung up to tension again.
if not, have a read through this:
fender's set-up guide for strats
all the best.
damo7v is offline
post #6 of 10 (permalink) Old 06-12-2005, 08:40 AM
jemaholic's Avatar
Really not a big deal unless you've got the micro-tilt neck...just sounded wierd the way you worded the question....like oops, now what have I gotten myself into?....
post #7 of 10 (permalink) Old 06-12-2005, 08:30 PM Thread Starter
TVE
Smile Re: Set up after removing the neck..help please :-)
Thanx everyone.
Tom, havent adjusted the screws too tight, just tight enough not to be loose.
Jemoholic..cheers, can appreciated how this may have been read :-) LOL
damo7v, know what you mean by letting it settle down was tension tightened...she was going out of tune for a short while :-)
Yes I do have a micro tilt neck,
Cheers
Tania
TVE is offline
post #8 of 10 (permalink) Old 06-13-2005, 01:51 PM
I have a microtilt neck on my G&L and I never use the feature. If I do, I have to raise the action....
red5 is offline
post #9 of 10 (permalink) Old 06-14-2005, 11:49 AM
jemaholic's Avatar
If you ever do - - just make sure you loosen the neck bolts prior to adjusting the micro-tilt, or else you can mess it up....
post #10 of 10 (permalink) Old 06-15-2005, 02:40 PM
Yeah, I'm not a setup noob
I tried using it, and I might be using it a wee bit (I forget) but i found the neck was tilted right anyway!
red5 is offline
fender strat , neck bolts
Removing neck dot inlays ANT5150 Tech: Setup, Repairs and Mods 6 03-02-2008 07:54 AM
Removing neck-finish straymond Tech: Setup, Repairs and Mods 8 07-01-2006 02:45 AM
SZ520 - Removing Gloss on Neck ric232 All Other Guitars (including Prestige) 7 09-30-2005 01:58 PM
removing the neck dc_mally Tech: Setup, Repairs and Mods 2 04-25-2005 05:48 AM
Removing the Neck on a 7DBK!!! Chipiem Ibanez JEM, UV, JS & Other Signature Models 6 04-03-2003 03:53 AM
