Small mod questions - Jemsite
post #1 of 3 (permalink) Old 02-21-2001, 02:52 PM Thread Starter
Small mod questions
I wanna basically setup my 7620 like Ryan has his blue 7620 setup, with the volume in the tone position and a mini switch in the old volume position. I don't know what Ryan uses but I want to use an on/on/on switch which I'm guessing means the position it is in is the one thats on and the other two are off, can anyone confirm this? Also can someone confirm that it can be setup neck hum/both/bridge hum? I hope to do this so I can mute the guitar with the flick of a switch when in the bridge and neck positions and so I can have a single coil active in the bridge when in I think the 2nd position. *
Noodles is offline
post #2 of 3 (permalink) Old 02-21-2001, 03:23 PM
Small mod questions
Noodles,
I'm using a 2 throw switch -- on/on, I guess.
However, I simply connected the wires which originally went to the tone pot to the switch on one side, and left the other side open. *When the open side is selected, you have sound. *When the other side is selected, it shorts out the whole guitar and kills all signal.
When I wired it up at first, I cut wire to the output jack and spliced the switch in between. *However, in this configuration I got a little bit of bleed-thru when it was supposed to be turned off.
As for selecting pickups, I'm still using the stock 5-way. *I'm not sure about how you'd wire the three-way toggle to select pickups.
ryan is offline
post #3 of 3 (permalink) Old 02-21-2001, 03:56 PM Thread Starter
Small mod questions
I see what your saying, it sounds a lot to complete than what I was gonna try. Thanks for the help.
Noodles is offline
bridge hum , neck position
Small size... 6fingers Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 06-19-2012 02:36 PM
WTB Barber Small Fry kinoble Classified Ads: Guitars and Gear 0 09-16-2007 11:10 AM
need opinion on small rig adamcbest Gear, Equipment, Recording & Off Topic 3 09-04-2007 07:35 AM
Need a small practice amp... waylay00 Gear, Equipment, Recording & Off Topic 10 04-23-2007 12:58 PM
Ibanez JS Questions!!! - Please answer these questions I hav Ibaman Ibanez JEM, UV, JS & Other Signature Models 6 09-08-2001 02:10 PM
