Soft fret wire - Jemsite
post #1 of 13 (permalink) Old 04-17-2012, 06:43 AM Thread Starter
Soft fret wire
Hi folks,
I bought an RG1570 about 5 months ago, and I've noticed that the frets are already starting to show some slight signs of wear. Specifically, there are scratches along the frets caused by the windings of the strings. They are still superficial, but deep enough that you can slightly feel them with the fingernails.
I have other guitars, including much cheaper ones, played them for years and they do not show these symptoms.
Is this normal for the Prestige line? Should I expect to have to refret the instrument after only a few years?
maddm is offline
post #2 of 13 (permalink) Old 04-17-2012, 07:03 AM
Re: Soft fret wire
Depends on how on top of dressing them you stay.
Get them dressed, they are very rough from the factory anyways.
musikron is offline
post #3 of 13 (permalink) Old 04-17-2012, 09:29 AM
webmaestro's Avatar
Re: Soft fret wire
When I got my 1527M about a month ago... fresh from the factory... the fretwire was somewhat "rough." In other words, the frets didn't have a slick, mirror polish and instead showed normal "fresh off the assembly line" roughness. These appear as faint little lines in the frets that run the same direction as your strings (as opposed to across the frets, in the direction you would bend a note).
So, I did what I normally do to brand new guitars and polished them up. I hit them with Micromesh papers... #800 then #1000. Lastly, I hit them with #0000 steel wool. This removed the roughness and brought them to a mirror shine.
If yours came with similar "rough" frets, and you didn't buff those out first, your frets could pit and scratch as you fret and bend strings. On the other hand, when frets are highly polished, they're less prone (I think) to premature pitting and wear.
webmaestro is offline
post #4 of 13 (permalink) Old 04-17-2012, 11:25 AM
Reviews: 21
Re: Soft fret wire
I think the newer Prestige models do use cheaper wire. My 20th RG and '06 RG1570 seem to have similar wear to my '01 which has many more hours logged in and is, of course, older. I also have cheaper Indo RG's that don't seem to show as much wear. Go figure.
mike570 is offline
post #5 of 13 (permalink) Old 04-17-2012, 02:59 PM Thread Starter
Re: Soft fret wire
Well that's bull****. So in 3-4 years I expect the frets will be worn to the point where they'll need work. Honestly I would have expected more from a Prestige. What was the problem with using stainless steel frets? There aren't any luthiers in my area so I have to do all the work on my guitars myself. And fret dressing/refretting is one of the more complex jobs...
Oh well, it's a great instrument otherwise... very comfortable to play.
maddm is offline
post #6 of 13 (permalink) Old 04-17-2012, 04:47 PM
Re: Soft fret wire
The frets have not changed.
Rich is online
post #7 of 13 (permalink) Old 04-17-2012, 05:20 PM
rgx
Re: Soft fret wire
So why they wear out quicker then?
rgx is offline
post #8 of 13 (permalink) Old 04-17-2012, 05:42 PM
Re: Soft fret wire
They don't.
OP, that's not fretwear, that sharp windings cutting into tops of the frets. Usually the result or high fretting pressure. I've done this myself back when I had much heavier left hand, I'm older and I play much lighter now.
Rich is online
post #9 of 13 (permalink) Old 04-19-2012, 10:25 PM
Re: Soft fret wire
I can wear out a set of frets in a year but I do PLAY A LOT,light touch but I DO PLAY A LOT....
mr_rainmaker777 is offline
post #10 of 13 (permalink) Old 04-19-2012, 10:50 PM
Reviews: 21
Re: Soft fret wire
There's got to be something different. My 20th RG is the worst of the bunch. Yeah it's five years old and I play a lot, but I usually rotate guitars to give them somewhat equal time. The '01 RG570 essentially sat in a gig bag from 2002 to 2005 so it's kind of close in age.
mike570 is offline
post #11 of 13 (permalink) Old 04-19-2012, 11:38 PM
Re: Soft fret wire
All I can tell you is I asked Junji a few years ago and he said the supplier and specs have never changed for all RG jumbo's.
Rich is online
post #12 of 13 (permalink) Old 04-20-2012, 11:29 AM
Re: Soft fret wire
That doesn't mean the supplier hasn't changed the wire on them.
musikron is offline
post #13 of 13 (permalink) Old 04-20-2012, 12:46 PM
Reviews: 21
Re: Soft fret wire
Maybe I'm wrong and I've been pounding on the RG20th more than I recall.
There definitely seems to be a difference between MIJ and non-Premium Indo.
mike570 is offline
rg1570 fret wire soft
dunlop pre-cut fret wire walterh Tech: Setup, Repairs and Mods 3 05-21-2010 01:59 PM
Fret wire quality... stratquebec All Other Guitars (including Prestige) 3 06-11-2009 06:16 PM
J-custom Fret Wire kmanick All Other Guitars (including Prestige) 0 05-04-2009 11:10 AM
Gold Fret wire? freakout Tech: Setup, Repairs and Mods 9 04-15-2008 07:14 PM
Fret Wire Devon8822 All Other Guitars (including Prestige) 3 07-19-2007 10:08 PM
