spring lock block? - Jemsite
post #1 of 8 (permalink) Old 03-12-2011, 07:53 AM Thread Starter
Question spring lock block?
hello there,
i was doing some service on my ibanez RG270 (LO/TRS floyd) and when i tried to put it all back together,the springs kept popping out of the total block now i have seen that there are blocks to keep the springs in place where could i get such block?
thanks in advance
leon
leonwiekenthemnie is offline
post #2 of 8 (permalink) Old 03-12-2011, 07:57 AM
Re: spring lock block?
Try Vox humana.
Death.by.G-string is offline
post #3 of 8 (permalink) Old 03-12-2011, 11:06 AM
is the block the wrong way around ?
dragsternj is offline
post #4 of 8 (permalink) Old 03-12-2011, 05:07 PM Thread Starter
no, this is kinda hard to explain but, with the spring you have the round side and the hook side, the hook side goes into the trem block, and on top of all the 'hooks' there is mostly a block to keep them from popping out, but i cant seem to find them anywhere , suggestions?
p.s. vox humana didnt have them
post #5 of 8 (permalink) Old 03-12-2011, 05:29 PM
RGTFanatic's Avatar
are there threaded holes in you block?? I didn't think the TRS had them, only the higher end trems........ I'll go look at one of mine....BRB
RGTFanatic is offline
post #6 of 8 (permalink) Old 03-12-2011, 05:32 PM
RGTFanatic's Avatar
mine does NOT have threaded holes in it for a hold-down bar. Mine is a Lo-TRS2 so yours may be different.
post #7 of 8 (permalink) Old 03-12-2011, 07:24 PM
Does your trem block have four small holes to put the spring hooks into and two larger holes for the two screws that will hold the spring retainer bar in place?
ashbass is offline
post #8 of 8 (permalink) Old 03-13-2011, 08:13 AM Thread Starter
yeah, it has five holes, and i thought the screws could go in the second and fourth, but now that i have looked at them, they will be really small for the screws, so i guess i will be searching on then, thanks anyway
ibanez springs floyd
WTB: Block Lock ohioplayer Classified Ads: Guitars and Gear 2 06-22-2007 03:07 AM
For Trade: 31mm Edge spring block for 41mm block mtxsho93 Classified Ads: Guitars and Gear 0 04-02-2007 05:29 PM
Edge Spring Lock question LonePhantom Tech: Setup, Repairs and Mods 15 01-21-2007 01:09 AM
Where can i get a block lock? schecter_blue Tech: Setup, Repairs and Mods 0 08-01-2005 07:08 PM
edge spring block lock, does it affect tuning stability satchman Tech: Setup, Repairs and Mods 5 03-03-2003 09:21 PM
