Static noise coming from humbuckers - Jemsite
post #1 of 7 (permalink) Old 06-16-2005, 07:37 AM Thread Starter
Reviews: 5
Hello
1. I have a jackson RR and the pickups create a very distinguishable static noise when I turn the volume up or down.
It is the most prominent when I hit open strings.
When I hold notes it seems fine but when the string rings out more noise.
The pickups are the jackson standards that come with it.
2. How do you replace the control knobs?
Thanks
wildchild247 is offline
post #2 of 7 (permalink) Old 06-16-2005, 07:26 PM
Re: Static noise coming from humbuckers
Perhaps you could clean or oil the inside of the pots first.
I don't use spray contact cleaner because it can come into contact with guitar's finish. Not good.
A light oil can be applied directly inside the pot, with the control cavity cover removed.
Try that, moving the knob back & forth, if pots are scratchy.
Otherwise, replacing is ... removing knobs, removing pots, de-soldering, re-soldering.
Strat Man Dwight is offline
post #3 of 7 (permalink) Old 06-30-2005, 10:52 AM Thread Starter
Reviews: 5
I am not too sure of the technical terms
pot??
I have no idea
Sorry
Wildchild247
post #4 of 7 (permalink) Old 06-30-2005, 10:57 AM
Might be an earthing problem.
the.godfather is offline
post #5 of 7 (permalink) Old 07-03-2005, 09:56 PM
Potentiometer
http://en.wikipedia.org/wiki/Potentiometer
dragsternj is offline
post #6 of 7 (permalink) Old 07-04-2005, 04:16 PM
If the wood is protected by metal like a Les Paul, spray some silicon spray in the pots. Wipe excess spray off and it will not do any harm. Bet that will help!
red5 is offline
post #7 of 7 (permalink) Old 07-04-2005, 04:18 PM
pot??
Yes, another term for marijuanna. It's a drug.... you smoke it!
red5 is offline
cavity cover , control knobs , les paul
very soft 'hum'-noise coming from bridge PU (CrunchLab7)? Santuzzo Pickups & wiring 1 02-02-2014 02:38 AM
Horrible noise coming from effects pedals Dannymanc81 Gear, Equipment, Recording & Off Topic 7 09-29-2012 02:25 AM
nasty noise from prestige rg (that high fret warbling noise that you DONT want) superhairycamel Tech: Setup, Repairs and Mods 10 07-04-2008 08:00 AM
Amp is making a lot of static/noise pradador Gear, Equipment, Recording & Off Topic 0 01-25-2008 11:34 PM
Strange static noise coming from my Telecaster Deluxe Superuser Tech: Setup, Repairs and Mods 3 12-18-2005 08:32 AM
