String gauge for 25.5 scale seven string? - Jemsite
post #1 of 14 (permalink) Old 04-17-2012, 04:30 AM Thread Starter
Reviews: 59
I'm waiting for my first seven to be delivered and I'm trying to figure out what seasoned seven string users are recommending for string gauge.
The guitar has 25.5 scale and a Floyd Rose locking system.
I have a few packs of .009-.054's from d'Addario as I prefer .009's on my six strings with the same scale, as my higher string bending is just so much more pain free over time compared to 10's.
Ideally I'd get a custom set of light tops/heavy bottoms, but that is impossible to find here in Europe.
Is there any great pros and cons on going up to .010's compared to staying with .009's?
hp29 is offline
post #2 of 14 (permalink) Old 04-17-2012, 04:56 AM
Re: String gauge for 25.5 scale seven string?
Pros in going to 10's = better tone, better tuning stability, better playability, longer string life, more responsive feel.
Cons= none
musikron is offline
post #3 of 14 (permalink) Old 04-17-2012, 05:02 AM
Contributor
sebastian's Avatar
Smile Re: String gauge for 25.5 scale seven string?
Cons= none
+1 and more responsive to faster picking
When I pick fast on 9s they take longer to get back to center, so I can't play as fast on speed runs.
Bending is the only hardship of 10s, just push or pull with more than one finger behind your bend.
sebastian is offline
post #4 of 14 (permalink) Old 04-17-2012, 05:25 AM
Impossible to find in Europe are you kidding?! Just order them online there must be loads of stores that stock say Dean Markley 9-54 or similar
Eg. http://www.stringsdirect.co.uk/searc...%40weight+DESC
guitarnoize is offline
post #5 of 14 (permalink) Old 04-17-2012, 05:52 AM
I bend 13's all day long, I can't even stand to tinker on a guitar with 10's. If you can't bend a ten clear off the fretboard, then you need to practice more and exercise those muscles!
musikron is offline
post #6 of 14 (permalink) Old 04-17-2012, 07:26 AM Thread Starter
Reviews: 59
.009-.054 isn't excactly top heavy...
hp29 is offline
post #7 of 14 (permalink) Old 04-17-2012, 07:29 AM Thread Starter
Reviews: 59
Sebastian, musikron; thanks for the tips.
Yeah I guess I should muscle up the fingers. And practice my bending technique...
hp29 is offline
post #8 of 14 (permalink) Old 04-17-2012, 08:21 AM
Somebody should tell Joe and Steve they need to practice more and develop more muscles so they can play a heavier gauge
Gauge is all about personal preference, not what anybody else out there says about it. If you prefer the feel of 9's, and I'm definitely in that group, then you should stick with 9's. I do like the little extra tonality from 10's but I hate the feel, and I'll take feel as the preference in that case. If you want to try 10's and you can get comfortable with the feel is up to you.
Rich is online
post #9 of 14 (permalink) Old 04-17-2012, 02:45 PM
Reviews: 11
Standard tuning - .10-.46 with a low .62 or .64 for the B
Drop A - .10-.46 with a low .70 or .72 for the A
Pretty much every 7 string set ever put together is wrong.
EX: A .46 in E get's oh, I don't know, let's say 19 pounds of pressure. We'', using a .56 for your B, will only get you about 13 or 14 pounds of pressure. Which is not enough tension. That's loose to the point of going out of tune every time you touch it.
Pro's for 10's: The first 6 are rightish.
Con's: Low B is far too loose. Same with .11's.
Balanced string tension is a wonderful thing.
D.M.RG7620 is offline
post #10 of 14 (permalink) Old 04-17-2012, 02:47 PM
Reviews: 11
Ever given the Kurt Mengens (I think that's what they're called) a try? My dad swears by them. They play like .09's but sound like .10's. Really awesome strings!
post #11 of 14 (permalink) Old 04-17-2012, 05:50 PM
I'm in the camp that say you can always make your fingers stronger, but you can't make thin strings sound fatter.
I'd take the approach of "If you get the tone you like from a specific guage, then you should muscle up and get used to the thicker guage. Your arms can handle it, and so can your fingertips, its just a matter of spending a while until your finger strength catches up to the guage, just like when you started playing".
On the other hand, sometimes you need a thinner guage for a thinner sound. I don't think 9's will ever sound properly like Stevie Ray Vaughan for example, but I'm just as sure that 13's will never sound like Dimebag.
GuitarBizarre is offline
post #12 of 14 (permalink) Old 04-17-2012, 06:14 PM
It has nothing to do with strength. It's the way they feel, how much tension you have to fight. Even when I had monster pads on my tips I didn't like the feel of 10's, not that I don't overbend sometimes as a result. And now that I may play 15-30 minutes a day I have almost no pads and heavier gauges are just plain uncomfortable to play. I have to do the setups I'm asked to and if it's 13's at pitch I know I'm in for a rough testing round. But I have to say I love 12's in C standard!
Rich is online
post #13 of 14 (permalink) Old 04-17-2012, 06:47 PM
*shrug*
In my experience, whenever I've moved up a guage, after increasing my finger strength, they've felt like standard guage. Its only immediately after moving up or down that I notice a real difference in feel. Excepting that thicker guages can be set with lower action, but thats not so significant overall.
post #14 of 14 (permalink) Old 05-18-2012, 06:21 PM
I thought the above correct (in my experience) for a while. I am a nut for intonation and getting the most and best tuning out of every chord possible while having a clean and articulate sound (I use heavy, high Gain sounds, tech metal prog rock). I used 10-46 and 62 on my 7620 for over a year and though it sounded fine everywhere but the low B was off, stiff, harder to play in tune on any chords with a low B.
So I decided to go against what I was told and what I learned about string tension and I slapped a 56 on the low B. Its now in Tune, sounds great and articulate. Chords sound nice and there is no slop at all.
Every guitar "lives" in a different place when it comes to a setup (strings, intonation methods, neck relief, etc...). My 7620 lives with Daddario (I HATED Dadarrios for years and still wont put them on my others) 10-56....everyting else just doesnt sound right on it.
Experiment, test, listen and feel....find out where yours lives.....Dont settle. You will be amazed at what you may find
py36 is offline
& string baritone string gauge axechain All Other Guitars (including Prestige) 6 02-09-2007 06:33 PM
String guage on short scale (i.e., Les Paul) vs. long scale gkelm All Other Guitars (including Prestige) 2 01-09-2004 02:14 AM
Ibanez AF 207 7 string jazzer-24.7"scale?? - Scale length is speedball Comments to Ibanez 12 01-12-2003 09:44 PM
String Gauges. - What gauge do you use on your 7-string? RedFive All Other Guitars (including Prestige) 36 12-02-2001 11:14 PM
