Strings buzzing when not touching them... - Jemsite
post #1 of 4 (permalink) Old 09-04-2007, 10:09 PM Thread Starter
...on my RGA121. specifically the A and low E strings. i'll pluck the 3 highest strings and they hum slightly, making high clean licks with distortion impossible.
i got it professionally set up, i don't think it was doing this before i got it set up for 10's...there's also slight fret buzz on the low e string, should i just go back to 9's or does the problem lie within the set up?
Thanks.
EDIT: He also had to cut out a little of the nut to put the 10's in. could that be the problem?
SomeDude49 is offline
post #2 of 4 (permalink) Old 09-05-2007, 02:47 AM
GAZ
Re: Strings buzzing when not touching them...
From your description it's not clear what the problem is, but obviously there is one, take it back to the guy that set it up, get him to sort it out and don't use him again !!!
GAZ is offline
post #3 of 4 (permalink) Old 09-05-2007, 05:20 AM
if you mean that the strings buzz only on open strings it is down to;
Nut slots cut too deep or nut not shimmed high enough - make the nut higher, i have no experience of doing this on none locking nuts.
Neck bowing the wrong way due to bad truss adjustment, but this would also cause problems on the other lower frets, not just open strings.
Take it back to him or better yet, use the internet to learn how to do setups yourself - its very easy, u just have to be patient.
Satchriossi is offline
post #4 of 4 (permalink) Old 09-05-2007, 06:17 AM
Sounds like sympathetic vibration due to either body vibration or harmonic overtones. The lighter the gauge, the more you'll get. You could always try lifting your pickups slightly to see if the increased field damps the vibration, but you'll lose sustain.
Slight fret buzz isn't the end of the world if only at the lowest couple of frets and if it's not sounding through the amp it shouldn't really be a problem. Raise the action slightly in need.
Honestly it just sounds like it's been set up for a light touch rather than a total disaster of a job.
DavyH is offline
fret buzz , locking nut , locking nuts , neck bow
Replaced strings.. 9s, but now some frets are buzzing! offie Tech: Setup, Repairs and Mods 3 07-02-2006 02:24 AM
Buzzing After Replace New Strings ibanezrg2570 Tech: Setup, Repairs and Mods 3 02-16-2006 07:55 PM
Known history of Guitar.. (lots of people have it wrong) - a vwall Archived Topics and Common Questions 20 12-30-2001 12:44 PM
How do you stop open strings from buzzing? - my high e and b puppiesonacid Tech: Setup, Repairs and Mods 4 08-20-2001 12:51 AM
Known history of Guitar.. (lots of people have it wrong) - a vwall All Other Guitars (including Prestige) 10 05-09-2001 01:20 AM
