Stripped screw threads - Jemsite
post #1 of 6 (permalink) Old 01-30-2016, 06:26 AM Thread Starter
Hi guys!
First of all I'm really sorry if I managed to double post this thread. My last thread just disappeared for some reason because of some login issues and I'm not able to find it again.
Anyway, I have a problem with my Ibanez RG2550Z. While adjusting intonation I managed to overtighten two of the screws that hold down the saddle units, resulting in stripping of the screw threads in the bridge plate. This means I cannot set intonation right anymore on two of the strings. I really want to fix this problem. My guitar has an Edge Zero tremolo bridge. What are my options? Do i have to buy a new bridge or can I just buy a new bridge plate? Is the Edge Zero and Edge Zero 2 interchangeable?
All help is appreciated!
Stringsound12 is offline
post #2 of 6 (permalink) Old 01-30-2016, 10:37 AM
RGTFanatic's Avatar
Re: Stripped screw threads
IIRC, your best option is to tap the threads to a larger size, but I don't know how much bigger you can go before a set screw diamater will be too big for the saddle to go around it. You can also use a helicoil kit to tap the holes larger, install the helicoil insert, then use the standard size set screw but you'll probably have to grind the bottom of the insert flush to the bottom of the baseplate.
RGTFanatic is offline
post #3 of 6 (permalink) Old 01-30-2016, 12:06 PM Thread Starter
Thanks! I might give it a try myself or I'll hand it over to my luthier. I'm not sure how much room there is for a bigger hole, but I think there should be enough for a small increase in screw size.
post #4 of 6 (permalink) Old 01-30-2016, 01:19 PM
Any decent machine shop can helicoil the threads to the original size.
Rich is offline
post #5 of 6 (permalink) Old 01-30-2016, 01:36 PM
RGTFanatic's Avatar
THIS^^^ Is probably the best way to go about the fix. I think trying to go to a larger size will be unsucessful. There's just not enough room in the saddle slot to put a large enough screw that will get good bite.
post #6 of 6 (permalink) Old 01-30-2016, 04:12 PM Thread Starter
All right, then I'll try that. Thanks a lot guys!
a wood stripped threads solution ? Methyl methacrylate panix Tech: Setup, Repairs and Mods 7 12-15-2015 12:40 PM
Possible stripped pivot screw on lo pro trem Wyvern Claw Ibanez JEM, UV, JS & Other Signature Models 12 02-21-2012 01:27 AM
Stripped out Screw chaztrip Tech: Setup, Repairs and Mods 5 08-30-2008 11:19 PM
Stripped Intonation Adjustment Screw guitar_man_6 Tech: Setup, Repairs and Mods 4 05-28-2007 02:17 AM
@#@#@$#!!! stripped locking nut screw, 7 hours before a gig! Drew Tech: Setup, Repairs and Mods 17 04-26-2003 05:12 PM
