suggestions for my to-be-made custom made 7 string guitar? - Jemsite
post #1 of 8 (permalink) Old 05-06-2005, 01:36 AM Thread Starter
elo,
1. I'm looking to order a custom-made 7 string electric guitar with tremolo.
2. the features of the guitar in full, that I want (comments are welcomed):
- 7 string electric guitar with tremolo.
- body that as thin as 'blackmachine' guitar (http://www.blackmachine.co.uk).
- super thin body, thin neck, very light in weight, short neck, small body, small distance from fret to fret, low action, with tremolo.
- marvellous sustain in the sounding of the guitar
- big range from very bassy to very trebly EQ wise in the sounding of the guitar (can have the option of switching from humbucker-like to single coil-like sound, vice versa)
- smooth movement on fingerboard as the fretting hand moves up and down the neck, no bumps and other friction in place.
- features as evident in http://schecterguitars.com/spec.asp?id=24
- Gloss Black in color; refer to http://schecterguitars.com/spec.asp?id=24
- low-B tuning based (around like .056 for the low-B?), of course having the option using the same string to further downtune to A, or G, as of other 7 string guitars in the market.
3. comments/feedbacks/suggestions are welcomed.
thanks!
ninelives1980 is offline
post #2 of 8 (permalink) Old 05-06-2005, 01:44 AM
Re: suggestions for my to-be-made custom made 7 string guitar?
Sounds like a monster .
Regards
André
fettouhi is offline
post #3 of 8 (permalink) Old 05-06-2005, 02:50 AM
I think you should goto blackmachine and talk to the guys there, from what I've seen guitars that thin take a while to get right, especially as you want plenty of sustain from the guitar
Papa_Shank is offline
post #4 of 8 (permalink) Old 05-06-2005, 03:05 AM
Who are ya lookin to make the guitar?
ibanezrocker61 is offline
post #5 of 8 (permalink) Old 05-06-2005, 04:59 AM Thread Starter
I'm based in Malaysia. So, if you do know anyone good, in Malaysia or Singapore, or other places nearby do let me know.
post #6 of 8 (permalink) Old 05-06-2005, 10:02 AM
BAD idea - a 25.5" scale is really as short as you want to go on a 7, to keep that low B intonating correctly. Even the 24 3/4 on the Epi Les Pauls is too short - any shorter than that (ESPECIALLY if you're tuning down to A or G) would be disasterous.
Sure, a shorter scale would let you do wide interval stretches easier, but it'd come at a HUGE cost for low-string definition and intonation.
If you want to tune to G, I'd recommended going to a LONGER scale - a 1077/2077 from Ibanez is 27" as I recall, and feels only marginal;ly "stretchier" than a 25.5, but gives you a much crisper low end. That'd be my recommendation.
-D
Drew is offline
post #7 of 8 (permalink) Old 05-06-2005, 11:33 AM
jim777's Avatar
Sounds like you want an Ibanez AX-7521. No need to go custom, and they typically run $250 used in good shape. It might be worth getting one to see if it fits your needs, and if not, just put it back in the 'Bay.
jim777 is offline
post #8 of 8 (permalink) Old 05-06-2005, 02:48 PM
-D
yeah, for tuning lower than B on a 7 stringer I wouldn't use a scale shorter than 27", the meshuggah lads were using UV777BKs for "nothing" and said that they were constantly having to retune the guitar and how bad the intonation was
funny you mention the 2077XL, I just so happen to have on for sale (maybe the threadstarter would be interested)
anyway, basically you want a scale of around 27" - 28.5"
electric guitar , epi les paul , les paul , les pauls , string guitars
Custom, hand made guitar for 300? Ok :) linuxpenguin All Other Guitars (including Prestige) 7 02-26-2011 12:35 PM
FS: custom-made 7-string Tele bridges Scott of Actual Time Classified Ads: Guitars and Gear 0 03-02-2008 04:43 PM
F/T or F/S Custom made 7/6 string double neck tobe Classified Ads: Guitars and Gear 0 01-13-2008 06:56 PM
FS: 7 string Ibanez LA Custom Shop made for David Fiuczynski Ambitot Pu Phang Classified Ads: Guitars and Gear 18 11-26-2006 08:19 AM
Custom made lefthanded 7 string fettouhi All Other Guitars (including Prestige) 5 09-02-2003 02:21 PM
