Sustainer pickup question - Jemsite
post #1 of 1 (permalink) Old 04-26-2005, 12:08 AM Thread Starter
Yes, I realize this is another Sustainer post but I looked through quite a few and didn't see these questions answered.
My basic goal is to have a guitar with a Sustainer system of some sort with standard 5-way switching - H-S-?. Ideally the '?' would be a mini-humbucker but I'm open to other options.
Fernandes Sustainer
  • FSK 401 - it comes with a bridge humbucker - I've read that the system does not work properly with any other bridge pickup. Can anyone confirm this?
  • FSK 401 - assuming you can use any bridge humbucker and operate properly, is there any reason you'd need to use the volume and tone pots?
  • FSK 401 and FSK 101 - does the Sustainer pickup function as a "normal" pickup when the sustain mode is off?
  • FSK 101 - does it look like you could yank the dummy pickup cover off easily? If so, it'd be a cheaper way to go than the 401 and still be able to wedge a mini-humbucker next to it.
Sustainiac
  • Stealth Plus - this version works as a "normal" neck pickup. How is the tone? A comparison to a well known pickup would be handy.
  • We've all heard what Steve can do with a Fernandes system. Has anyone used both the Fernandes and the Sustainiac? If so, can you compare/contrast the two systems in terms of performance?
hippietim is offline
bridge hum , bridge humbucker , bridge pickup , fernandes sustainer , neck pickup , pickup cover
Sustainer pickup idea crazyninja95 Tech: Setup, Repairs and Mods 6 11-14-2012 10:39 AM
Bridge pickup to use with 101 sustainer Oz1 Pickups & wiring 2 04-11-2010 11:39 AM
Which pickup for jem 7vwh with sustainer.. Adnoctum Pickups & wiring 3 05-31-2008 06:17 PM
pickup in neck with sustainer? -Rhaab Tech: Setup, Repairs and Mods 1 11-17-2006 12:34 AM
WTB: Sustainer pickup Davey Classified Ads: Guitars and Gear 0 07-15-2005 04:18 AM
