swapping lo pro for edge original - Jemsite
post #1 of 5 (permalink) Old 11-09-2004, 10:40 AM Thread Starter
simple question. will the edge original fit in place of the lo pro edge on both the 6 string and 7 string models?? I realize there might be some modification, but is it generally posible without too much fuss.
Thanks
adamcbest is offline
post #2 of 5 (permalink) Old 11-09-2004, 01:08 PM
Lo Pro and original edge will replace each other.
Ibateur is offline
post #3 of 5 (permalink) Old 11-10-2004, 10:13 AM
Also, they are completely interchangeable...you won't need to modify your guitar.
rory is offline
post #4 of 5 (permalink) Old 11-10-2004, 11:05 AM Thread Starter
my buddy has an rg520 with an original edge. it seems to hit the body pretty early on pulling up. the bottom of the trm bar anchor hits inside. how do i go about fixing this?? oh the trem has been jsut set up and the trem angle is correct. so this isn't the problem. My first guess was just routing out where it's hitting some, but i wasn't sure this ws ok to do
post #5 of 5 (permalink) Old 11-10-2004, 01:34 PM
All it needs is a neck shim
Rich is offline
neck shim , pro edge
Swapping out an edge 3 EXshad Tech: Setup, Repairs and Mods 5 11-23-2010 12:11 PM
Some quick questions about swapping to an Edge Pro.. hotwax1989 Tech: Setup, Repairs and Mods 5 09-21-2009 02:36 PM
Edge swapping Vaibanez Tech: Setup, Repairs and Mods 1 07-29-2009 04:12 PM
Lo-TRS II ??? - swapping with an Edge and more wulpul Archived Topics and Common Questions 16 01-07-2006 08:25 PM
swapping EP/EP II with original edge stratman219 Tech: Setup, Repairs and Mods 3 04-28-2003 01:28 AM
