trem angle trouble - Jemsite
post #1 of 7 (permalink) Old 07-07-2004, 11:17 PM Thread Starter
trem angle trouble
hey y'all, i put on a .58, and a set of 9's on my RG1527 a few hours ago, i originally had a 9-54, the same as stock size ibanez. anyway, my trem angle is way high, action IS where i want it about, but the angle is too high up from the cavity, i was wondering, since the claw is already screwed in up to where the threaded screw part stops, if i can screw more into it to pull it down into the body without damage or bad stuff happening to my new $600 guitar
analogcreature is offline
post #2 of 7 (permalink) Old 07-07-2004, 11:57 PM
Replace or add springs...Considering I use a 10-52 set with a 60 on a long scale, a piddly 58 shouldn't have raised it that much. Possibly weak springs. Try replacing them, or add one and see what's up. If the claw is screwed in that far, I don't know what else could be wrong.
Akhenaten is offline
post #3 of 7 (permalink) Old 07-08-2004, 01:28 AM
Some of the screws thread the whole shaft, some stop 1/2" from the head. Either way screw it in as far as you need to.
Rich is offline
post #4 of 7 (permalink) Old 07-08-2004, 04:28 AM
Re: trem angle trouble
Just to add my tuppence (love that word) and to echo Rich, out of the 5 or 6 7 string ibanez i have owed, all have been screwed in PAST the thread end, this is no big problem, and is totally safe from all points of view, Just grab a screwdriver and sort the angle out :-)
HTH ... BTW both my UV and RG7Custom are screwed to about 2 or 3 mm away from touching wood with .10's and a bottom .60 ... All my guitars have 3 springs, always :-)
Rob
Jem7RB MK is offline
post #5 of 7 (permalink) Old 07-08-2004, 05:41 PM Thread Starter
ok thanks everyone for your help, i screwed in teh claw a bit more and tuned up and after the second run thru teh strings, everything was in tune, low action, perfect trem angle. im a happy camper
post #6 of 7 (permalink) Old 07-08-2004, 07:47 PM
I think Ibanez should start setting these things up with stock guage 10's.
I don't know what gague the masses use, but I find 9's a pain in the neck.
My 1527 took a me a while to set up too.
Societysucks is offline
post #7 of 7 (permalink) Old 07-09-2004, 11:13 PM Thread Starter
i actually like the 9's on all my strings but then a heavier .58 on my low B for that meatier tone
Trem angle paison90 Tech: Setup, Repairs and Mods 7 04-09-2011 11:47 PM
lo -pro trem angle jem_fanatic Tech: Setup, Repairs and Mods 8 06-23-2006 10:49 AM
Trem angle B1Zzar3 Tech: Setup, Repairs and Mods 5 01-24-2005 11:36 AM
Need help with lo-pro trem angle... ibanezlover Tech: Setup, Repairs and Mods 4 08-27-2004 11:50 PM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 06:37 PM
