Trem posts on RGT 3120 TDB - Jemsite
post #1 of 1 (permalink) Old 04-30-2002, 03:19 PM Thread Starter
I had a clicking noise coming from the treble side trem post almost everytime I depressed the bar. It always occurred when I would raise the bar and then depress the bar. The solution was very easy. I replaced the trem post. I was lucky to find some older trem posts (the bottom angle was wider that the original posts that came with the RGT). When I replaced the trem posts I looked at the knife-edges and they appeared to be ok. So far it has fixed the problem. Let's hope it does not return.
Out,
GP
pri0531 is offline
trem posts won't go further down! straymond All Other Guitars (including Prestige) 5 11-07-2012 04:05 PM
Best Trem Posts LonePhantom Tech: Setup, Repairs and Mods 12 05-02-2008 10:52 AM
replacing trem posts btangel Tech: Setup, Repairs and Mods 5 07-14-2005 03:01 PM
where can I get the trem posts for the Edge trem? rx Ibanez JEM, UV, JS & Other Signature Models 6 03-17-2005 08:24 PM
LO TRS II TREM POSTS rgtojem Tech: Setup, Repairs and Mods 8 12-04-2003 10:20 PM
