Trem replacement options 440sII - Jemsite
post #1 of 7 (permalink) Old 03-20-2012, 12:34 PM Thread Starter
Just bought this off ebay (although the guy advertised it as a 540s with Floyd). The action seems high and the trem saddles look like they are as low as they can go. Now, I guess the posts on the trem "could" be sunk lower in the body...but that is last choice. Has the HQ-J trem now.
So what options would I have for a replacement fit. Now, I don't need a FR style trem at all, as I really would not use a trem at all...so just something that would fit and improve the action.
Any ideas?
Kaldorlon is offline
post #2 of 7 (permalink) Old 03-20-2012, 05:29 PM
Re: Trem replacement options 440sII
That's interesting that you can't get better action, I've had a couple of those and had no issue with the action. That being said, I don't know of a replacement trem that will fit either. Maybe the neck needs to be shimmed to give you a little more angle to the body?
gpenguins is offline
post #3 of 7 (permalink) Old 03-20-2012, 08:05 PM
RGTFanatic's Avatar
As Penguins said........I would START with a neck shim and go from there. If you can't bring the strings closer to the neck, then bring the neck closer to the strings.
RGTFanatic is offline
post #4 of 7 (permalink) Old 03-21-2012, 08:53 AM Thread Starter
Thinking about this for an option.
guitarfetish has a Floyd Rose Fastloader that would drop in to this stud spacing now...for around $65.
post #5 of 7 (permalink) Old 03-22-2012, 08:28 AM
Usually adjusting the height/action on a FR style trem IS done at the post.. raising and lowering the bridge.. if you need the bridge to stay at the height it is now.. for a bolt on guitar.. you'd shim the neck but putting shims in the neck pocket on the body side of the pocket. Most Floyd style trems don't allow for raising and lowering individual saddles without having to shim each individual saddle and this is usually only done to radius the bridge to match the curvature/radius of the neck when it doesn't match up with the bridge well enough to have even action across the neck from string to string.
JackButlerGOT is offline
post #6 of 7 (permalink) Old 03-23-2012, 04:18 PM Thread Starter
Well I took apart the saddles and cleaned everything up...trem looks 100% better. Did play with the posts and it moved it down quite a bit. Going to have my tech do a full set up/intonation on it though.
Also, (am going to get killed by the Ibanez community), I am replacing the pickups with lipsticks. Humbucker and 2 singles...going to coil tap the humbucker. I love the feel of Ibanez guitars, but want that lipstick strat sound..so going to try it with this one.
Black GFS lipsticks (as they were out of the chrome neck and middle)..since guitar is black and stock pickups were black (and I didn't want to wait for whenever the chromes came back in stock), pulled the trigger today.
So hopefully get the pickups next week and a week or so for tech/install/setup work..in a couple weeks will have my "dream" lipstick guitar.
post #7 of 7 (permalink) Old 03-23-2012, 04:19 PM Thread Starter
Thanks for the reply post on the trem...Ironically I just saw you the other day on DVD (I love putting in the last 20 mins of that movie, starting at the crossroads scene..lol).
Edge Pro Replacement Options OliverKlohzoff Tech: Setup, Repairs and Mods 3 02-01-2010 07:05 PM
Edge Zero replacement options. scotteggshell All Other Guitars (including Prestige) 8 02-25-2009 07:32 PM
JS 1200 Trem blockage/replacement options... Valhalla Ibanez JEM, UV, JS & Other Signature Models 15 07-20-2008 06:46 PM
Ibanez RG neck replacement options cosmitron Tech: Setup, Repairs and Mods 1 12-07-2007 10:36 AM
G-Major replacement options? JiMoSiTY Gear, Equipment, Recording & Off Topic 14 03-11-2004 07:33 PM
