Tremolo tension - Jemsite
post #1 of 3 (permalink) Old 10-24-2010, 08:36 AM Thread Starter
Tremolo tension
Hey everyone.
I have an ibanez prestige rg1520a installed with an edge pro trem
it is setup with gauge 10-52 (hybrid set) in d standard tuning.
now the trem is fairly stiff (which is no problem since i use it for bend-like things and vibrato and not divebombs) and it is installed with 3 springs. the claw is screwed in to where you can only see few mm of the "twisted" part of the screws.
is this bad? its my first trem so i have no experience. should i loosen the claw and install more springs?
system32 is offline
post #2 of 3 (permalink) Old 10-24-2010, 05:49 PM
Re: Tremolo tension
Seems normal for 10s.
Ke^in is offline
post #3 of 3 (permalink) Old 10-24-2010, 06:32 PM
Reviews: 98
Re: Tremolo tension
If it's floating where it should be, then you're OK. Make sure that the BASEPLATE of the Edge is parallel to the body, and not the TOP WEDGE. If this is good, and you stay in tune, there is no need to adjust the claw screws from where they are.
AlaskaBat is offline
tremolo springs
Problem of string tension on UV7BK'97 with 12-68 set and Tremolo-No nmanel Tech: Setup, Repairs and Mods 4 09-22-2008 12:17 AM
string tension and spring tension choubix Tech: Setup, Repairs and Mods 4 06-11-2007 03:21 PM
Tremolo tension jpi Tech: Setup, Repairs and Mods 4 03-28-2003 05:55 PM
Tremolo Bridge Height leads to increased tension? genesis Tech: Setup, Repairs and Mods 4 02-24-2003 10:08 AM
