TRS, Lo Pro, Edge trem cavities - Jemsite
post #1 of 12 (permalink) Old 04-28-2005, 12:39 AM Thread Starter
Are all trem cavities routed the same? Whether it be for an Edge, or Lo Pro, or TRS trem? What I thought was a 7620 is actually a 7420, and I ended up buying the wrong parts. If the routing is the same I'll just order a new Low Pro trem. Thanks!
tone_connoisseur is offline
post #2 of 12 (permalink) Old 04-28-2005, 01:41 AM
Re: TRS, Lo Pro, Edge trem cavities
I dont think they are the same .... you cant swap lo pro to edge pro but not TRS to edge or lo pro ...
That's what i believe but wait for the others...
ciao
Ced
(sorry im french translation is bad and poor from what i want to say ...)
Cedric777 is offline
post #3 of 12 (permalink) Old 04-28-2005, 03:11 AM
They are not the same...
bpd111 is offline
post #4 of 12 (permalink) Old 04-28-2005, 06:47 PM
you can swap lo pro to edge pro but not TRS to edge or lo pro ...
Is this correct??? I have always thought you could swap Edge Lo Pro with the Edge model. No Edge/Edge Lo Pro to Edge Pro. That's completely different animal. TRS to OFR is possible. TRS to Edge/Edge Lo Pro might require some routing.
Jemmm is offline
post #5 of 12 (permalink) Old 04-28-2005, 06:57 PM
Flobanez's Avatar
My UV7PWH and RG 7620 have the L Pro Edge and my S 7420 has the TRS.
I wanted to replace the TRS on my S with a Lo Pro Edge....
but sadly it's not going to happen.
Flobanez is offline
post #6 of 12 (permalink) Old 04-29-2005, 04:22 AM
Then just replace it with an OFR, that's just a choice.
Regards
André
fettouhi is offline
post #7 of 12 (permalink) Old 04-29-2005, 04:29 AM
Nothing but an Edge Pro will swap for an Edge Pro, the intonation point is different from every other tremolo on the market, Ibanez included. YOu also can't put the Edge Pro in a body that wasn't designed for it.
The Edge and Lo-Pro Edge are interchangable with each other.
The TRS rout is different from the Edge/Lo-Pro Edge rout, and you have a 10% chance of an Edge fitting in without having to rout, 90% of the time you'll need to remove some wood. The OFR and OFR-7 should fit the TRS rout though, and are a much better trem than the TRS.
toshiro is offline
post #8 of 12 (permalink) Old 04-29-2005, 04:35 PM
just to further confuse the issue, i asked recently about replacing an EP2 with anything good/better.
never did get a response.
is there a resource that outlines the physical dimensions of these trems and their routings? maybe a table of what (if any) are interchangeable?
that'd be great, and probably save a heap of quesions.
damo7v is offline
post #9 of 12 (permalink) Old 04-29-2005, 04:54 PM
The reason why nobody responded to your question is that nobody knows. From what I have read the Edge Pro and II/III are not interchangeable. The same applies for the switch to Edge and Lo Pro Edge. Then the last thing would be to go to a OFR or Gotoh FR, there I don't know the answer.
Somebody needs to try this and then report back here. Now who is going to be the first test person .
Regards
André
PS. In the end you should be able to swith to any trem (mentioned above) is might then require routing of some sort (everything mentioned above assumed that no routing needed to be performed).
fettouhi is offline
post #10 of 12 (permalink) Old 04-29-2005, 06:17 PM
i may have read this wrong.. but i think on LGM's site, a trs to edge trem rout ws listed in the services and it was only like 30 bucks. if you have an s 7 string you want to be an edge model.. i'd send it to him. 30 bucks for the rout is more than worth it. look into it. I think the trs routing of the latest s 7 string was the downfall of that model. i'd rather have the edge 7 than an OFR 7
adamcbest is offline
post #11 of 12 (permalink) Old 05-01-2005, 12:27 PM
Only problem with sending it to LGM is that he doesn't do these small jobs anymore because he's so backed up at the moment.
Regards
André
fettouhi is offline
post #12 of 12 (permalink) Old 05-01-2005, 12:49 PM
There's a tutorial here about changing from a TRS to an Edge/Lo-Pro but it requires routing and all sorts.
http://www.projectguitar.com/tut/trs2lopro.htm
JTM45 is offline
edge trem , pro edge
FS: Double Edge Trem (piezo equipped trem) Guitarmattms Classified Ads: Guitars and Gear 0 01-23-2014 10:12 PM
xiphos with edge pro trem and original edge studs/anchors ibanguitar All Other Guitars (including Prestige) 2 10-15-2013 10:45 PM
How to remove ZR trem, destroy it, then install Edge trem? bdk Tech: Setup, Repairs and Mods 16 07-25-2010 01:33 PM
FT: Black Cosmo Lo-Pro Edge Trem for your Chrome Lo-Pro or Original Edge Trem parker_fly Classified Ads: Guitars and Gear 4 02-19-2005 03:18 PM
WTB: Cavity covers for UV jack and trem cavities wemedge Classified Ads: Ibanez JEM/UV Guitars 0 12-01-2004 09:17 PM
