Tuners for this neck/headstock - Jemsite
post #1 of 13 (permalink) Old 12-14-2008, 12:49 PM Thread Starter
Question Tuners for this neck/headstock
Hi. I've just bought this ibanez neck for a rg project.
What tuners/machine head will fit there? There are 2 screw holes...
I need brand and model so that i can order... Gotoh? What model?
Thank you.
Regards
BTW post preview... post the topic....
Brohymn is offline
post #2 of 13 (permalink) Old 12-14-2008, 04:33 PM
Reviews: 120
Re: Tuners for this neck/headstock
They are Ibanez cheaper tuners. You can get Gotoh standard inline tuners (which are used on the Prestige MIJ Ibanez) which will cover the two holes, and you'll just need to drill a hole to install them. Much better than finding a set of the original tuners as they aren't that great.
LonePhantom is offline
post #3 of 13 (permalink) Old 12-14-2008, 05:12 PM Thread Starter
Thanks.
So this one should fit?
http://www.stewmac.com/shop/Tuners/G...s.html#details
Regards
Brohymn is offline
post #4 of 13 (permalink) Old 12-14-2008, 08:06 PM
those gotoh tuners would fit through the hole yes, but you'd still have to drill holes in the headstock.
these on the other hand, are the tuners meant for that headstock.
http://cgi.****.com/NEW-Ibanez-Tunin...3286.m20.l1116
that's an eb4y link, PM me if u need it.
Foulacy is offline
post #5 of 13 (permalink) Old 12-14-2008, 10:16 PM
Reviews: 120
Yeah those are the standard ones, but the Gotohs will be much better. Yes you have to drill a hole, but I'd much rather do that and put in the higher quality Gotohs.
post #6 of 13 (permalink) Old 12-14-2008, 10:21 PM
it has a locking nut. as long as the tuners hold pitch for long enough to lock the nut, theres absolutely no point to making those modifications for the sake of gotohs. THe stocks will be fine.
GuitarBizarre is offline
post #7 of 13 (permalink) Old 12-15-2008, 02:25 AM
my thoughts exactly.
Foulacy is offline
post #8 of 13 (permalink) Old 12-15-2008, 03:31 AM
Reviews: 120
Considering the Gotohs are only a few $$$ more, and will most probably last a lot longer than the stock ones i'd still go with the Gotohs.
post #9 of 13 (permalink) Old 12-15-2008, 07:55 AM Thread Starter
Thanks guys. Drilling a hole is not a problem. I just want make sure that the tuners cover those two holes.
regards
Brohymn is offline
post #10 of 13 (permalink) Old 12-15-2008, 08:11 AM
Tuners are hardly the first thing I'm thinking of when i try to list the parts that are going to break on a guitar. Good ones are nice, but I personally would rather avoid un-needed modification.
Besides, the gotohs won't cover the holes from the front, only the back, if my guess is correct. Those holes go all the way through the headstock. YOu'd need a massive ugly washer to cover them from the other side.
post #11 of 13 (permalink) Old 12-15-2008, 03:26 PM
Well if you look at the picture of the front of the headstock you can see that the holes don't go all the way through. Or at least are covered by the black veneer.
AxeHappy is offline
post #12 of 13 (permalink) Old 12-15-2008, 04:41 PM
Reviews: 120
The Gotohs cover everything they would need to. I wouldn't have suggested them unless I, and others had found that from experience.
I don't know why you thought the holes went right through the headstock either, I mean the OP provided pics, you can see they don't.
And those cheaper ones do break, I am speaking from experience.
post #13 of 13 (permalink) Old 12-15-2008, 07:03 PM
I just didn't check the pics, I thought the second pic had it showing light through the 2 holes.
Ibanez reverse headstock tuner upgrade to locking tuners question. unconventional Tech: Setup, Repairs and Mods 9 04-04-2008 12:20 PM
Is this repairable? Cracked neck/headstock Scoff X Tech: Setup, Repairs and Mods 9 08-30-2005 11:43 PM
Neck specs for ordering new Locking tuners on RG headstock? gemini8026 All Other Guitars (including Prestige) 6 12-04-2002 12:22 AM
