Using TRS Saddles on an Edge Bridge - Jemsite
post #1 of 2 (permalink) Old 10-05-2015, 08:32 PM Thread Starter
Is it possible to use TRS steel saddles on an Original EDGE bridge?
I have spare EDGE baseplate with block on order so thinking if I could re-use the saddles from a a Japanese Takeuchi TRS bridge with the EDGE.
Thoughts?
xperiate is offline
post #2 of 2 (permalink) Old 10-06-2015, 01:57 AM
Reviews: 6
Re: Using TRS Saddles on an Edge Bridge
the edge baseplate is graded so all the edge saddles are the same height...if the saddles from the trs are different heights because of a flat base plate then i think you'd prob run into some problems matching the radius of your fretboard...but alas i know nothing of the trs trems so it's just food for thought...d.m.
diablomozart is offline
edge , saddles , takeuchi
WTB: Edge Pro II bridge saddles guitz Classified Ads: Guitars and Gear 0 09-08-2010 11:10 PM
WTB: 2 GOLD Ibanez EDGE Pro bridge saddles shreddyknight Classified Ads: Guitars and Gear 1 06-11-2010 04:46 PM
can you shim bridge saddles... Dragon Slayer J Tech: Setup, Repairs and Mods 4 12-07-2007 10:56 AM
New saddles? or new bridge? SuperJemBoy All Other Guitars (including Prestige) 4 03-01-2005 02:46 AM
