USRG Neck rattle - Jemsite
post #1 of 4 (permalink) Old 05-24-2001, 10:54 PM Thread Starter
USRG Neck rattle
I just aqquired a USRG30-TBQ.
I have noticed a rattle in the neck. Like the truss rod is loose or somthing like that.
I have never touched one of these guitars until today and certainly know crapola about the Tension Free necks.
Can anyone help?
J>
Vaibanez is offline
post #2 of 4 (permalink) Old 05-25-2001, 03:48 PM
site founder 0% owner
jemsite's Avatar
USRG Neck rattle
where is the rattle... by the headstock, heel-joint? I assume this is not something simple like the pressur pads rattling and everything has been inspected OK... glen
jemsite is offline
post #3 of 4 (permalink) Old 05-25-2001, 07:40 PM Thread Starter
USRG Neck rattle
It feels like it's right in the middle of the neck.
Nut, pads, neck screws and headstock are tight. I gave the truss rod a small turn (1/8 of a turn, if that) *and the rattle seems to have gone away....strange.
I just got it, (Thanks Tom Cook) so this weekend it gets a setup. But I don't think it's anything to worry about. I'll keep you guys updated.
J>
Vaibanez is offline
post #4 of 4 (permalink) Old 06-14-2001, 03:40 PM
USRG Neck rattle
Since it doesn't actually have a "truss rod" per se, the steel rod is actually acting as the neck, absorbing all the tension. You can almost consider the neck itself there for your enjoyment, because it would be awfully hard to play a steel rod. Since the rod flexes independently of the neck, there can be creaks and rattles as they touch. I took mine apart (side allen bolt out, neck allen bolt out, nut connection plate out, remove headstock by pulling it) and coated the rod with linseed oil. I debated between that and something thicker like car grease. I wish I would've used the car grease because it would last longer in there. Anyway, When I put it back together the noise was 100% gone. *It was the rod and the wood creaking like a door hinge. If it's rattling when you play certain notes then you have to figure out a way to keep it put. Even then, a thick grease should absorb that too.
frankfalbo is offline
neck screws , truss rod
WTB USRG 30 with Tension free neck metalguy Classified Ads: Guitars and Gear 0 01-22-2012 08:09 PM
rattle in RG1570 neck Mister CCJ All Other Guitars (including Prestige) 1 02-20-2007 09:30 AM
Neck- Headstock Joint on USRG - What is it? caprile All Other Guitars (including Prestige) 6 08-26-2001 11:30 AM
usrg-30 - the little hole in the neck... Eddie B All Other Guitars (including Prestige) 17 04-05-2001 07:32 PM
USRG Neck Adjustments - Techniques DTSteve Tech: Setup, Repairs and Mods 3 12-26-2000 12:55 AM
