Variations in the original Edge? - Jemsite
post #1 of 17 (permalink) Old 05-22-2013, 08:55 PM Thread Starter
I removed a mid to late 80's pro line Ibanez egde trem. I compared it to a later early 90's trem and discovered 2 things. The block on the earlier trem is bigger. Also, the trem posts on the earlier are longer. I guess my question is...will the earlier trem still work on later models? Why did I do this? I have no idea.
TECHNOROCKTRONIC is offline
post #2 of 17 (permalink) Old 05-22-2013, 09:04 PM
Reviews: 120
Re: Variations in the original Edge?
Yes it does. I have a late 86/early 87 Edge that I retro-fitted to my RG 470. Block is longer obviously, but it just means that you leave the cavity cover off.
LonePhantom is offline
post #3 of 17 (permalink) Old 05-22-2013, 09:26 PM Thread Starter
The length of the trem posts did not give you any problems?
post #4 of 17 (permalink) Old 05-22-2013, 09:56 PM
Reviews: 120
I didn't get trem posts with mine.
Easiest way to to find out is just try installing the posts. You're not going to break anything.
post #5 of 17 (permalink) Old 05-23-2013, 07:50 AM
Contributor
sebastian's Avatar
I have what you are talking about.
I had to get a short block for the trem, it was an easy swap out in just a few minutes.
The inserts and posts are toooo long, you'll need new ones as well.
sebastian is offline
post #6 of 17 (permalink) Old 05-23-2013, 09:02 AM
I've heard of the "long blocks" but have never seen one. It makes sense that they were used on earlier models, which probably didn't have recessed trems.
There are other subtle differences if you have a couple of them around. Up through about '88, the fine tuners had a very pronounced beveled edge and the saddles have much softer edges. If you see a more recent Edge, the saddles have very sharp edges.
Takin' a Ride is offline
post #7 of 17 (permalink) Old 05-23-2013, 09:57 AM
Contributor
sebastian's Avatar
The trem arm socket stuck out of the base plate on some of the older ones.
post #8 of 17 (permalink) Old 05-23-2013, 11:34 AM
First run Edge: 41mm block; longer non-locking studs (quite pinched, actually, so up-bends with trem – though minimal because guitars were non-recessed – have sharp return) with hollow inserts; spring plate doesn't have notches for the string lock bolts; arm socket sits higher; pronounced fine tuner bevel.
Another thing I found interesting was the '86 spec arm (bottom):
The earlier arm has a gentler curve, bend further up, and the spring slot is different. The newer one is taller - I guess they did it when trems became recessed to compensate.
Ashurbanipal is offline
post #9 of 17 (permalink) Old 05-23-2013, 03:30 PM
RGTFanatic's Avatar
Here are some pics from my '86 RG410 as compared to an '89 Edge:
RGTFanatic is offline
post #10 of 17 (permalink) Old 05-23-2013, 05:38 PM
Reviews: 120
OK, yeah those studs are much taller. Won't be able to set decent action on a recessed trem without cutting the stud down.
I reckon these longer blocks sound a lot better too. Increased mass helps, but I think the makeup of the metal may be better tone wise too. I'd keep the cavity cover off and use the long block for the tonal benefits.
post #11 of 17 (permalink) Old 05-23-2013, 09:25 PM Thread Starter
Thanks guys!! There is always a wealth of knowledge on these boards.
post #12 of 17 (permalink) Old 05-23-2013, 09:46 PM
I think that the metal of the blocks is the same, but the early ones were just painted black.
Because of the architecture of the trem owing to the longer block, these early ones feel a bit stiffer than the recessed ones.
post #13 of 17 (permalink) Old 05-23-2013, 10:11 PM Thread Starter
I am gonna sell my older larger block if anyone is interested. I replace it with a smaller one so I can use the back cover plate.
post #14 of 17 (permalink) Old 05-24-2013, 05:02 PM
hello everybody Im boing to build custom rg body and also have that old stylish Edge. I've already shorted studs and inserts and modified them to locking studs. Alltoght I'm going to building custom body I will leave that long block as is (someone mentioned it's 41mm long) to get a better sound and sustain. Cen someone tell how long is that smaller block to know how much I will have to extend body thikness. Thanks to advanced.
Živeli!
shalipur is offline
post #15 of 17 (permalink) Old 05-24-2013, 05:08 PM
sorry for grammar and writting mistakes
shalipur is offline
edge trem posts block
Fast Tracks in a Jem? - Pickup Variations Christopher Chen Ibanez JEM, UV, JS & Other Signature Models 18 07-05-2011 06:25 AM
WTT: Black Original Japanese Edge > Chrome Original Japanese Edge lewis.mann Classified Ads: Guitars and Gear 0 11-23-2008 04:03 PM
WTB: Edge Pro Tremolo or Trade for mint Original Edge For_The_Love_Of_Jems Classified Ads: Guitars and Gear 3 02-12-2008 01:24 AM
Quartersawn JEM FP neck stability and variations Metallion Ibanez JEM, UV, JS & Other Signature Models 1 07-11-2007 07:07 PM
Jem 7VWH colour variations Wolfram Ibanez JEM, UV, JS & Other Signature Models 18 03-13-2007 04:21 PM
