Volume Pot Seizing - Jemsite
post #1 of 6 (permalink) Old 07-20-2008, 10:21 PM Thread Starter
Volume Pot Seizing
Hey guys I have a 2007 Rg2570 and my volume pot has seized up, after I get a proper size flathead to get the damn thing off I'll see if there is anyway of saving the thing. If not should I just buy a pot from Rich or are there better pots that will sound better than the ibanez ones or would it be risky for my tone to chg model pot?
newbieguitarmaker is offline
post #2 of 6 (permalink) Old 07-21-2008, 10:09 AM Thread Starter
Re: Volume Pot Seizing
Any ideas on which volume pot to get guys?
post #3 of 6 (permalink) Old 07-21-2008, 10:18 AM
Ayrton's Avatar
Just grab a 500k CTS pot locally and swap it out.
Ayrton is offline
post #4 of 6 (permalink) Old 07-21-2008, 10:30 AM
Mine seized up in my RG550 20th ann. and I used the CTS pot but had to widen the hole in my pickguard and I also needed extra washers underneath to keep the height correct. I wouldn't think your tone would be affected negatively by using a non-Ibanez pot, if anything I would think there would be improvements due to the higher quality of the CTS pots.
screamndemon69 is offline
post #5 of 6 (permalink) Old 07-21-2008, 10:37 AM Thread Starter
ok, I will probably take out the pot and compare it to the ones at my local shop to see if its pretty much the same size because if the hole has to be bigger on my guitar I'd have to cut wood but I definitly believe that a non-ibanez pot would probably sound better since they seem higher quality than ibanez's, at least recent pots.
post #6 of 6 (permalink) Old 07-21-2008, 02:28 PM
Sometimes you can save an old pot by spraying it with some contact cleaner and working it around. It might be worth a try, before you replace it.
just4kinks is offline
Which Volume Tank Gear, Equipment, Recording & Off Topic 5 12-07-2007 08:40 AM
Volume @ Home S-man Polls 27 08-01-2006 01:11 AM
Volume Pot johnnyd529 Ibanez JEM, UV, JS & Other Signature Models 2 05-09-2006 06:07 PM
Volume Pedals trouble311 Gear, Equipment, Recording & Off Topic 1 03-03-2004 03:23 PM
Volume Pot Scott 74 Tech: Setup, Repairs and Mods 16 09-21-2001 05:54 PM
