What is the difference between front routed and rear routed? - Jemsite
post #1 of 10 (permalink) Old 04-06-2012, 12:57 AM Thread Starter
*50 means HSH configuration front routed, *70 means HSH configuration rear routed.
What does "front routed" and "rear routed" mean?
Thanks!
ironfistx is offline
post #2 of 10 (permalink) Old 04-06-2012, 01:41 AM
Reviews: 120
Re: What is the difference between front routed and rear routed?
Front routed, has a pickguard, routing for wiring on the front (top) of the guitar.
Rear routes, no pickguard, route for wiring on the rear (back) of body.
LonePhantom is offline
post #3 of 10 (permalink) Old 04-06-2012, 02:04 AM
Reviews: 64
Front routed means it's routed on its rear.
Rear routed means it's routed on its front.
6fingers is offline
post #4 of 10 (permalink) Old 04-06-2012, 11:30 AM Thread Starter
What does "routed" mean?
Is there a functional difference between the two or does it only come into play if you are messing with the internals?
post #5 of 10 (permalink) Old 04-06-2012, 11:45 AM
Reviews: 64
It means you should play instead of wasting time with that thing
6fingers is offline
post #6 of 10 (permalink) Old 04-06-2012, 01:28 PM
Reviews: 11
First: "routed" is the term for when you use a tool called a router to remove wood from the body of the guitar. And the specific routing that makes it either front or rear routed is for all of the electronics like the pickups and knobs.
Now. THIS is front routed. It is ugly to look at because there will be a pickguard over it so you'll never see it anyway.
THIS is rear routed. It is made to look nice and has a cover put over it. It leaves the front of the guitar looking nice and smooth.
Understand now?
D.M.RG7620 is offline
post #7 of 10 (permalink) Old 04-06-2012, 01:35 PM
LOL
chrisf is offline
post #8 of 10 (permalink) Old 04-06-2012, 03:13 PM Thread Starter
Understand now?
Yes, thanks!
post #9 of 10 (permalink) Old 04-06-2012, 05:05 PM
Reviews: 120
Gee I didn't realise that I didn't explain that earlier ironfistx....
post #10 of 10 (permalink) Old 04-06-2012, 08:03 PM Thread Starter
I can't read and need pictures to understand.
Are all Front-Routed Universes the same? Ekim Ibanez JEM, UV, JS & Other Signature Models 4 05-28-2011 08:50 PM
front routed swirls? coopertron Ibanez JEM, UV, JS & Other Signature Models 12 05-20-2009 05:24 AM
WTB: AANJ MIJ Front Routed RG Body caprile Classified Ads: Guitars and Gear 0 06-29-2008 06:43 PM
Rear routed/mounted? Front routed/mounted? Jeff Tech: Setup, Repairs and Mods 19 10-07-2002 05:36 PM
Front routed and swirled... - Has it been done? Darin W Ibanez JEM, UV, JS & Other Signature Models 7 09-23-2001 09:59 AM
