What RG is this? MIJ dimarzio pickups CUSTOM MADE - Jemsite
post #1 of 11 (permalink) Old 06-29-2014, 07:33 AM Thread Starter
Saw this guy selling this Ibanez guitar, the neck says its a RG series but I don't know if the body is a RG series body.
Dimarzio pickups, Made in JAPAN.
is this legit? the seller is demanding 270$ for this
HELP! Thanks
karimbaig is offline
post #2 of 11 (permalink) Old 06-29-2014, 07:47 AM
Re: What RG is this? MIJ dimarzio pickups CUSTOM MADE
Looks to me like its an s series, that someone cut the horns off of and glued on some rg shaped horns. If you look close you can see the glue lines under the paint up near the horns. Also, its a 22 fret neck square heel neck, they didn't put the "x series" label on till aanj so that was added as well. Kind of an interesting concept...could be a better finish job though.
Fastmerc is offline
post #3 of 11 (permalink) Old 06-29-2014, 08:06 AM Thread Starter
270$ is fine for this guitar?
post #4 of 11 (permalink) Old 06-29-2014, 08:13 AM
stratoskier's Avatar
I agree. Looks like they RG-ified an S540 and then painted over the "S Series" headstock logo to make it say "RG". I also agree that the year is uncertain due to the square heel + "... Series" label, but there were a number of oddities that appeared during those conversion years in the early 90s.
stratoskier is offline
post #5 of 11 (permalink) Old 06-29-2014, 08:16 AM
I'd say so. Dimarzio pups, great Wizard neck. Lo Pro trem. Seems like a good deal as long as they didn't screw up the neck in any way.
post #6 of 11 (permalink) Old 07-01-2014, 05:34 PM
Why would someone do this to an S540.....
jazzedout is offline
post #7 of 11 (permalink) Old 07-01-2014, 08:06 PM
Converting S-series guitars into other Ibanez models seems to be popular. For example... item #271535885795
post #8 of 11 (permalink) Old 07-01-2014, 11:26 PM
it looks like the RG in heavy diet.
psychoshredder is offline
post #9 of 11 (permalink) Old 07-01-2014, 11:35 PM
Yep, looks more like someone carved up an RG (the body is too thick for an S series), and then put a 22 fret S series neck on there.
wilch is offline
post #10 of 11 (permalink) Old 07-02-2014, 12:49 AM
I don't think this started life as an RG, but an S:
- The neck pickup is in the normal position of the S. If it was an RG the neck pickup would be more towards the bridge (24 fret neck)
- The backplates are from the S series. These couldn't fit an RG body.
- All hardware (including the beehive knobs) are period correct for an 90-91 S540. Is there a serial nr. behind the headstock?
- I bet that if we could see a pic of the depth of the body at the rear strap button, it would be normal S series depth.
As someone said earlier, this looks like an S540 with the horns modified to look like an RG... IMHO a very bad job...
post #11 of 11 (permalink) Old 07-07-2014, 12:55 PM
I you look closely on the forth picture you can see the lines where horns were cut off, plus RG body cant be shaped into this because of the cavities for the arm and body which RG has ans S doesn`t..
mtc777 is offline
custom , dimarzio , ibanez , mij , usa
Possibly getting a custom Fireman made; what pickups should I get? meticadpa Pickups & wiring 1 11-09-2010 04:07 AM
Post Pix of your custom-color Dimarzio Pickups jemaholic Pickups & wiring 3 01-18-2010 07:55 AM
Did Ibanez cheap out with their stock pickups? [no, they're DiMarzio made for Ibanez] TheJazzTerminator All Other Guitars (including Prestige) 224 08-18-2006 06:48 PM
WTB: Dimarzio Custom 7 or New 7 pickups divad Classified Ads: Guitars and Gear 1 10-20-2005 02:57 PM
Dimarzio RG7 Custom pickups unfashion All Other Guitars (including Prestige) 2 12-19-2003 08:41 AM
