Where to buy Edge or Lo Pro bridge? - Jemsite
post #1 of 2 (permalink) Old 08-25-2002, 05:16 AM Thread Starter
Hello,
I'm considering the option of buying an RGT42 as a project guitar and replacing the bridge since it should be considerably cheaper than buying an RGT3120. I've seen several discussions of replacing the TRS II bridge with an OFR, Edge or Lo Pro but have no idea how to purchase an Edge or Lo Pro. Can these be ordered through an Ibanez reseller or do you have to find used bridges pieced out on Ebay? If they can be purchased new, how much do the Edge and Lo Pro run? As a side note, I've seen people mention dropping in an OFR but I haven't seen any mention of the OFR II. The OFR II has a slightly smaller profile and isn't as bright as the OFR so I'd probably prefer to go with an OFR II all things considered even. Has anyone here replaced a TRS II with an OFR II?
Thanks!
Peter
DailyGrind is offline
post #2 of 2 (permalink) Old 08-25-2002, 06:22 AM
kirk's Avatar
If you have a local Ibanez dealer they should be able to order a new Edge or Lo-Pro for you, and if I am not mistaken cost is about $125.
Some people say that trying to order these through your dealer is next to impossible, however I have not had this experience. Best bet is to talk to a dealer yourself.
You can also check out that banner ad at the top of this page that says Ibanez Rules, and follow the parts link.
As far as the OFR, check the FAQ in this forum. This is a pretty common question, and the answer may be there.
Good luck.
kirk is offline
Closed Thread
ibanez dealer
WTT: my Gold Schaller FR bridge for your Black Lo Pro Edge or Edge bridge supergirl20_06 Classified Ads: Guitars and Gear 2 08-05-2011 05:57 AM
LF: Ibanez Edge or Lo Pro Edge bridge in Cosmo Black supergirl20_06 Classified Ads: Guitars and Gear 0 09-19-2010 10:02 AM
JS100 bridge swap??? Edge Pro / Edge Pro II n7uqa Ibanez JEM, UV, JS & Other Signature Models 8 06-04-2009 11:35 AM
Replacing an Edge FX (fixed bridge) with an Edge Pro or OFR? twooos Tech: Setup, Repairs and Mods 1 10-21-2007 07:06 PM
Edge bridge repairs - post & knife edge jd Tech: Setup, Repairs and Mods 6 12-09-2002 05:48 PM
