Why does X guitar scream high notes better then Y - Jemsite
post #1 of 6 (permalink) Old 05-01-2011, 12:13 PM Thread Starter
I've been playing Gary Moores - The Prophet and theres a section where the guitar realy gets up high around the 22nd fret on the high e string and screams. I've been rolling up my volume for my bridge pickup for more distortion and that seems to help with sustaining.
On a lot of guitars though, it seems harder to get sustain and volume out of the high notes and I end up picking the long notes on every beat to keep the sound going as they won't sustain it.
My gibson lespaul studio gothic has the most sustain out of my guitars but it doesn't seem to have the volume of my jackson sl2h soloist at these high notes.
So what is it that makes some guitars do this better then others.
Neck through body design? Pickups? Weight? Fret wood?
Is there anything i can do to make the guitar scream moore at these higher notes?
heres a quick sample of me playing that section, And appologies for some sloppiness since i've learnt it in the last 2 days.
http://www.supload.com/listen?s=3fPi9X
Crankitup85 is offline
post #2 of 6 (permalink) Old 05-01-2011, 12:18 PM
Reviews: 4
Re: Why does X guitar scream high notes better then Y
He was also likely to get a lot more sustain if his amp was at a decently loud volume.
fwd0120 is offline
post #3 of 6 (permalink) Old 05-01-2011, 01:14 PM
Reviews: 11
http://www.bossus.com/gear/productde...?ProductId=148
just bought one of these. Highly recommend it.
linuxpenguin is offline
post #4 of 6 (permalink) Old 05-01-2011, 01:20 PM
The amount of variables is unending. Guitar setup,amp,effects playing style,volume, etc..
Alot of times the players are using a wah to roll off low end and jack up treble on those notes.Volume pedal would do much the same thing if you opened it up full on for those notes you wanted to leap out. Also pick attack is huge some players hit super super hard to get added oomph,squeals,artificial harmonics, rakes. I know I saw Shawn Lane and he picked the hardest of anyone I have ever seen you could hear the pick hitting the strings even at relatively high volumes,a great part of why his legato was so nice one pick was alot of power to carry on the next 5 hammer ons and pull offs.Slash and Zakk Wylde use the wah for that same effect you are talking about making those high notes leap out.Zakk picks very hard as well.Trying using technique to get some of it and if that dont work try a wah pedal.Nice tone and a good amp always help as well.A compressor would help as well good idea Linux. Some other technique ideas to get some added zip finger pick in the octave of the note you want to stand out,instead of just playing the high E at the 12th fret add in the B string at the 15th fret and bend it to match the E then vibrato and use that added tone for more weight and variety,same idea on the G and the B strings bend the G to match the note you were gonna play by itself on the B just adds a little more weight to it.Picking is huge also use the edge of the pick rake a bit hit extra hard.You could also use your tone control start out with it like on 3 and when the part you want to jump out comes up go to like 11 with it adding treble high end,same applies to the volume knob, you could also start the solo with the neck pickup and switch to the bridge for the higher notes you want to jump out. Good Luck I'm sure you will figure it out.
corpraider69 is offline
post #5 of 6 (permalink) Old 05-02-2011, 12:01 PM
Reviews: 6
Be careful with a compressor, you maight loose all the dynamics you can create with your pick. I never use compressor just because of that.
satch_jr is offline
post #6 of 6 (permalink) Old 05-02-2011, 11:42 PM
what corpraider69 said, could be the wood of a particular guitar (not wood type but that particular cut), could be the pickups, could be frets who knows that's why it is always a good idea to play a guitar a lot before you buy it. Having said that I didn't play either of my last 3 guitars before I got them shipped from the US haha.
guitarnoize is offline
les paul sustain
Scream for me Sao Pauuuuloooooooo 6fingers Off-topic / Miscellaneous 0 03-26-2011 07:36 PM
no sustain when high notes ftw1422 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 9 12-23-2010 02:21 PM
The Satch Scream????? PrinceAlice Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 14 03-12-2009 06:29 PM
scream baby! scream! Dong Pickups & wiring 8 03-12-2005 11:26 AM
Guitar in "Dreaming" liner notes ashbass Ibanez JEM, UV, JS & Other Signature Models 12 02-25-2005 04:21 PM
