Why is the rg8570 more expensive than the rg3270 - Jemsite
post #1 of 4 (permalink) Old 05-29-2006, 05:15 PM Thread Starter
Question Why is the rg8570 more expensive than the rg3270
basically ive looked on GAK.com and aside from slight pickup difference why is the rg8570 more expensive than the rg3270.
Thanks.
ashton is offline
post #2 of 4 (permalink) Old 05-29-2006, 06:08 PM
Re: Why is the rg8570 more expensive than the rg3270
the RG8570 is a J-Custom. It also has the flame maple binding which the RG3270 doesn't have
buddroyce is offline
post #3 of 4 (permalink) Old 05-29-2006, 11:30 PM
ScottB's Avatar
Plus, 8570 is a much larger number than 3270.
ScottB is offline
post #4 of 4 (permalink) Old 05-30-2006, 04:02 AM
GAZ
Talking Re: Why is the rg8570 more expensive than the rg3270
Yes it is a pukka J Custom so has the recessed controls, angled/recessed jack socket, the JC all access neck joint and strap locks as standard. It also has flame maple neck binding with abalone side markers, and a matching flame maple headstock. The back of the headstock even has a maple and bubinga veneer which looks very classy !!! The different pup combination is just a matter of personal taste. So for 50 or so extra you're getting a lot for your money I reckon !! I've said most of this in answer to one of your previous posts actually !!??
'I used to be indecisive............but now I'm not so sure.......'
G.
GAZ is offline
access neck joint , flame maple , flame maple binding , flame maple neck , jack socket , maple binding , maple neck , neck binding , neck joint , strap lock , strap locks
buy expensive guitars and not play them? ZOMB13 All Other Guitars (including Prestige) 11 08-02-2005 10:05 AM
Question: RG2770 vs. RG8570 Robotechnology All Other Guitars (including Prestige) 6 06-27-2005 03:25 PM
Can i change an edge pro for a lo_pro edge on a rg8570 comando Tech: Setup, Repairs and Mods 1 04-26-2005 07:53 PM
J Custom RG1880 or RG8570? buddroyce All Other Guitars (including Prestige) 3 02-26-2005 06:10 AM
