Will EMGs fit in the RGA121 without modification??? - Jemsite
post #1 of 12 (permalink) Old 12-28-2005, 10:50 AM Thread Starter
I've heard some people say yes, some say no, so what's the verdict???
If I have to file the flaps down a bit, no big deal...Just want to know. Thanks.
-Joe
mityjoeyoungxnj is offline
post #2 of 12 (permalink) Old 12-29-2005, 01:22 AM
Re: Will EMGs fit in the RGA121 without modification???
I don't have a RGA121 so I'm only going to guess and tell you what I did. First I had to grind down the mounting tabs from square to round to fit into the body. The next part was the fun part. I had to rout the hell out of the body of the guitar to get the EMGs to sit low enough to clear the strings. The area under the quick connect plug was the worst as I had to take about 1/4 to 3/8 in of wood out to get them in there. I used a Dremel tool. I did this on a RGT3120. Hope it helps.
Donovan is offline
post #3 of 12 (permalink) Old 12-29-2005, 05:42 AM
To make a long story short:
Donovan is right and no, they won't fit (at least not without heavy modifications).
I own a RGA121VLF and had to return a pair of EMG89s, because especially the neck pickup cavity(?) was too small and not deep enough (at least for the 89, I was so embarrassed I didn't try any others).
juka is offline
post #4 of 12 (permalink) Old 12-29-2005, 06:12 AM
Reviews: 7
That's what sucks about EMG's, they need sooo much more depth than other pick-ups... EMG should think about making the mounting tabs flush with the bottom of the pups, it would make people less iffy about buying them questioning whether or not they'll need to do some routing...
brothersnowgone is offline
post #5 of 12 (permalink) Old 12-29-2005, 09:37 AM Thread Starter
Wow that sucks!! I guess I'll ne staying passive!! Which isn't really a bad thing. I'm thinking duncan custom bridge and PAF Pro neck. Thanks a lot dudes. You saved me lots of $$!!
-Joe
post #6 of 12 (permalink) Old 12-29-2005, 09:47 AM
Yeah, EMG's are an absolute pain in the behind. 90% of the time they will require routing to fit properly/snuggly. You will be far better sticking to the passive pickups as you say. Stick a nice set of Duncans in there, maybe a Custom and a JB. Or the Dimebag pickup - that pickup is so brash it has its own set of balls! lol
the.godfather is offline
post #7 of 12 (permalink) Old 12-29-2005, 01:05 PM
Originally Posted by the.godfather
...Or the Dimebag pickup - that pickup is so brash it has its own set of balls! lol
+1
That's what I've put in, after returning the 89s.
juka is offline
post #8 of 12 (permalink) Old 12-29-2005, 03:44 PM
EMGs will fit perfectly into guitars that have pickup rings like the regular RG series guitars. The problem with fitting seems to come into play with guitars that have direct-mounted pickups.
I love EMGs and all, but I personally think that an RGA is the wrong instrument for them in that it's SUCH a waste of all that beautiful tone wood.
lyconxero is offline
post #9 of 12 (permalink) Old 12-29-2005, 03:49 PM Thread Starter
hehehe, I'm kind of excited about going passive now. I love the duncan custom and will use that for bridge. PAF Pro for neck sounds good eh??
post #10 of 12 (permalink) Old 12-29-2005, 04:00 PM
Joe,
Put a Duncan Custom and a Duncan Jazz (neck) in there....that'll sound bonkers...the Jazz is a great neck pickup, warm but articulate as well.
TheOrangeChannel is offline
post #11 of 12 (permalink) Old 12-29-2005, 04:25 PM Thread Starter
Originally Posted by TheOrangeChannel
Joe,
True, never tried the Jazz...I know I like the PAF Pro, maybe I'll try the Duncan for the hell of it.
-Joe
post #12 of 12 (permalink) Old 01-06-2006, 02:28 PM
Keep in mind that the Duncans will still require you to round the tabs, shouldn't be any big deal.
Jazz/Custom is what I am installing in my RGA121/VLF, think I'm gonna go with Zebra's for a more classic look.
Ibby is offline
mounted pickups , neck pickup , paf pro , paf pro neck , pickup cavity , pickup ring , pickup rings , pro neck
EMGs in an RGA121? ryaneise Archived Topics and Common Questions 5 10-30-2010 01:42 PM
Amp Modification help wanted mike80sguy Gear, Equipment, Recording & Off Topic 0 10-08-2007 11:21 AM
Installing EMGs in an RGA121 nutbehindthewheel All Other Guitars (including Prestige) 15 09-27-2007 09:24 AM
Body Modification courtney2018 Tech: Setup, Repairs and Mods 18 08-08-2007 10:48 AM
Australian Amp modification wilch Tech: Setup, Repairs and Mods 9 01-25-2004 07:14 PM
