will a gibson bridge fit an epi les paul? - considering a lp - Jemsite
post #1 of 3 (permalink) Old 02-24-2002, 03:17 PM Thread Starter
hey continuing my search of a cheap guitar, i'm considering an epiphone les paul custom. i notice the bridge is not like gibsons. the height is adjusted by two screws, whereas the gibsons i've seen have thumbwheels. while the bridge seems good, i assume the gibson is better and shouldn't be that expensive to replace. any thoughts?
i also have a momentary urge to get the epi and get it 'bullseyed' like zakk's...
caprile is offline
post #2 of 3 (permalink) Old 02-24-2002, 03:55 PM
it should be a semi standard tune o matic bridge. it works the same way as the gibsons, only without the thumbwheels, and ive seen after market add on thumbwheels for that same application (dont know if they would work in your situation tho). I dont think they are really necessary, and you will prolly never have to readjust your bridge once its where you want it. I will, however, help you no more if you ruin the horrible name of epiphone by getting a zakk sprial on it.
and for the record, in my experience, the only difference between gibson parts and most others, is the price. plain and simple. if you are going to change the bridge, there are a host of options out there that you will most likely find that will suit you better than the gibson bridge. get somthing because its better, not because they stamped gibson on it
BZ Beetle is offline
post #3 of 3 (permalink) Old 02-24-2002, 04:25 PM Thread Starter
yes i agree, not gibson maybe but quality replacement. i have a fixed idea: epi parts suck. i'm sure most people agree.
caprile is offline
epiphone les paul , epiphone les paul custom , les paul , les paul custom , matic bridge
FS Gibson Les Paul Traditional, '57 Goldtop, 2008 Inc. Gibson Original Hard Case Epicus Furor Classified Ads: Guitars and Gear 6 07-25-2012 03:01 AM
Gibson Les Paul HELP !! xklusivly4u All Other Guitars (including Prestige) 13 11-11-2008 05:09 PM
FS: Gibson Les Paul Classic with Gibson hard case Davey Classified Ads: Guitars and Gear 6 10-07-2007 07:16 AM
WTT My Gibson Les Paul for your... Melodic Dreamer Classified Ads: Ibanez JEM/UV Guitars 12 06-21-2007 12:18 AM
Gibson Les Paul prv Classified Ads: Guitars and Gear 5 05-26-2006 07:53 PM
