Will a GOTOH floyd fit in my old RG270? - Jemsite
post #1 of 4 (permalink) Old 08-29-2007, 03:33 AM Thread Starter
with out any routing?
skykiller is offline
post #2 of 4 (permalink) Old 08-29-2007, 11:16 AM
Reviews: 3
Re: Will a GOTOH floyd fit in my old RG270?
I put one in my RG320DX and I believe my luthier had to re-drill.
finstah is offline
post #3 of 4 (permalink) Old 08-29-2007, 12:36 PM
Reviews: 4
Probably not. I fitted my RG-470 with an Original Floyd Rose Pro (the low profile version) and it was less than 0,5mm from the bottom side of the routing (high E string side). I decided to route the cavity a bit. I have also deepened it.
Crazy_Guitar is offline
post #4 of 4 (permalink) Old 08-29-2007, 07:49 PM
Reviews: 120
There's a good chance it will fit, but you may need to sand out the cavity a little to make it an even fit. (I've put one in an RG470 that originally came with a LO-TRS II)
If you want to use the Gotoh's locking studs you'll have to re-drill the holes a little bigger after pulling out the old ones too. It's worth using the Gotoh ones though.
definitely worthwhile upgrade if you have an attachment to the guitar.
LonePhantom is online
floyd rose , floyd rose pro , locking stud , locking studs
FS; 2000 RG320DX: EMG 81/60 Gotoh Floyd finstah Classified Ads: Guitars and Gear 4 09-07-2007 08:10 AM
Gotoh Floyd spacing funkdubious Tech: Setup, Repairs and Mods 2 07-25-2007 03:01 AM
Gotoh floyd rose misplacedsanity Tech: Setup, Repairs and Mods 4 05-12-2007 03:17 PM
Gotoh Floyd problem :( Shredcows Tech: Setup, Repairs and Mods 6 11-07-2005 12:25 PM
Gotoh, Schaller, or Original Floyd Rose? tomsthename Gear, Equipment, Recording & Off Topic 9 07-14-2002 11:19 AM
